Upgraded my speaker cables! - diyAudio
Old 17th February 2003, 09:36 AM   #1
Mendis is offline Mendis  Singapore
Default Upgraded my speaker cables!
Phew! after two hours of connecting and tidying up, I finally finished re wiring my car audio system with better speaker cables!
Results were good. but... the highs seems too outstanding now...
what can I do? someone suggested changing the tweeters..
Old 18th February 2003, 09:01 AM   #2
mrfeedback's Avatar
What sort of cable did you use ? - this can be a cause of overbrightness.
Eric.
I believe not to believe in any fixed belief system.
Old 18th February 2003, 09:07 AM   #3
summation OFC cables.
Is it? die lor... for the rear speakers ok. Front tweeters bright. Could that be the problem?
Old 18th February 2003, 09:57 AM   #4
mrfeedback's Avatar
Default What Is The Cross-Section Shape ?....
Moreso, I meant the physical construction of the cables that you are now using.
Low inductance is the key factor, and OFC is not so important as you may be lead to believe.
Eric.
Old 18th February 2003, 10:02 PM   #5
hi again! thanks for advising!
OK.. let's see.. its transparent and there about perhaps 8 guage cables... thicker than the zip cords that were used previously.
copper cables definitely.
Old 18th February 2003, 10:17 PM   #6
mrfeedback's Avatar
Putting an RC network across the tweeters will help, also a series resistor to pad the level down.
Eric.
Old 18th February 2003, 10:37 PM   #7
You mean gauge #8 or what? Perhaps you should try adding one or two thin wires to this cable and see if things improve.
One of the good things of using CAT-5 cables as speaker wire is that each cable consists of 8 thin solid-core wires.
If the cables you use are solid core or too thick, bass notes will be improved and highs impaired. It sounds as if that is happening to your system after the change.
Have you tried bi-riwing, with thick cable to the woofer and thin to the tweeter? Can you do that?
Carlos
F1 or F2 with MIT speaker cables? roscoeiii Pass Labs 1 13th July 2009 12:47 AM
T Amp speaker cables atldiyr Class D 8 30th November 2008 03:53 PM
how much did you pay for speaker cables peteS Multi-Way 43 12th March 2006 01:22 PM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
Copyright 1999-2017 diyAudio
