REALLY simple amplifier? REALLY simple amplifier? - diyAudio
Old 27th November 2007, 04:56 AM   #1
CalcProgrammer1 is offline CalcProgrammer1  United States
Default REALLY simple amplifier?
I've been searching for a really simple amplifier circuit that requires only transistors, resistors, and capacitors. I want this simplicity because I already have an assortment of those parts and want to build something without having to buy more parts. All I want to do is drive maybe 15 to 30W speakers from my PC's audio out. I've seen simple Class-A audio circuits that are simple, but none had part specifications or resistor values. I have 6V and 12V transformers I could use. Is it possible to build such an amplifier?
Old 27th November 2007, 06:04 AM   #2
Jonathan Bright is offline Jonathan Bright  Australia
Yes it is possible (most things are given time and money) The "Class A " website run by Geoff Moss for the Linsley Hood amp' is exhaustive for the home builder, try Google. I f the tranformers are for the the power supply you won't get the power you mentioned......then again you probably really don't need that much anyway. This amp' (The John Linsley Hood design) has it's own very large thread on this site. Put "JLH 10 watt class A" in the search funtion and you'll get well over a thousand posts. I imagine there are other designs around too. The chip amp' people also are worth a look if you want to spend a small ammount for an IC and relatively simple design. Good luck and welcome to the site. Jonathan
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 27th November 2007, 09:01 PM   #3
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Default Re: REALLY simple amplifier?
Do you want class A, can you manage the heat? 10 watt class A is a very big heatsink and maybe not what you are looking for on a PC. Considered Class AB? there are many designs around that will work with the transformers that you have.
Do you want such a circuit and how complex do you need?
Nico
Old 27th November 2007, 10:59 PM   #4
I'm looking for simple. Basically, I have some bookshelf speakers rated at 15W to 30W. My old PC (an HP) has an amplified out port, and I can plug the speakers directly into the port and run them fairly loud. I highly doubt it's actually approaching anywhere near 30W (maybe 5 at most) but it sounds good. My new PC has only a line-out. I'm looking for something really simple, I found one that used only a few resistors and a transistor or two, but it didn't have a part list or even the resistor values.
At this point I'm not caring too much about power efficiency or even sound quality, I just want to try something out for fun. I'd like to eventually get it to power an old car speaker as a cheap subwoofer (the speaker in question: NOM. 18W, MAX 35W, 6 OHM) which sounded really good when I plugged it into my parents' stereo amplifier.
Old 28th November 2007, 02:41 AM   #5
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
What are the parts you have? You'll need some fairly specific transistors to build an amp. You'll need a couple small signal types, a couple medium power types and a pair for output. Chances are you'll need to buy at least a few parts.
You might be better off with the chip amp solution (not nearly as fun though)
Transformers, you say 6V and 12V. Do you have one of each or more? Amps like split supplies.
Old 28th November 2007, 05:18 PM   #6
Nico Ras's Avatar
Default Re: Re: REALLY simple amplifier?
Those are the right questions to ask, John. Lets see what he has and then what we can do to help him.
Nico
Old 28th November 2007, 05:29 PM   #7
Nico Ras's Avatar
Another question CalcProgrammer1, are you capable of making or having a PCB made or need this be purely proto-type board. Give a little information of your capabilities so that we do not select either something to silly or to complex.
Old 28th November 2007, 05:36 PM   #8
DocLorren is offline DocLorren  Netherlands
Death of Zen by Rod Elliott.
I built it a few years ago. It is simple, sounds very good and gets HOT. What else do you want?
http://sound.westhost.com/project36.htm
Old 28th November 2007, 06:45 PM   #9
Nico Ras's Avatar
There is nothing like hot
Old 28th November 2007, 08:21 PM   #10
Nico Ras's Avatar
Here is Rod's circuit with a twist using a MOSFET as to output device
Set X1 for 12V at output.
REALLY simple amplifier?Hide this!Advertise here!
Simple Hi-end 845 amplifier audiodesign Tubes / Valves 57 2nd January 2009 07:09 PM
simple Amplifier? technics Solid State 38 31st March 2008 11:36 PM
Simple amplifier hobbit Solid State 15 27th January 2008 06:30 AM
simple amplifier bigspeakers Chip Amps 4 23rd June 2006 12:34 PM
need a simple amplifier DrSplodge Everything Else 12 28th July 2004 06:49 AM
Copyright ©1999-2017 diyAudio
