is 400w power amplifier enough for four 8 ohms, 15 inch 500w speaker?
#2 |
It should be plenty,
The 500 watt rating on the speaker is probably a "max" rating. |
#3 | |
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#4 |
It depends on the rated SPL 1-watt 1-meter and how loud you want it to be.
The wattage rating of a speaker is just the damage-rating not loudness rating
Just because you can't hear it doesn't mean no one can. |
#5 |
the lower the impedance the more chances of distortion.....
#6 |
If you wire the 4drivers in series parallel then the effective impedance is 8ohms.
Each speaker will get an equal share of the power delivered, i.e. a maximum of 100W of unclipped sinewave. A single driver with 100W of input will produce an SPL figure at the LF you require. Two speakers each fed with 100W will give SPL + 6dB Four speakers each fed with 100W will give SPL + 12dB Your 400W amp feeding 4off 8ohm drivers, wired as an 8ohm load, will sound as loud at LF as a 1600W amplifier driving an 8ohm speaker, if it could survive. You will be asking each driver to handle a maximum of 100W. They should be reliable and loud. Personally I would use four amplifiers each rated at 100W or so into 8ohm and power each driver individually. You get the same volume (SPL) of 1600W driving a single 8ohm speaker and you have resilience in your system. If one amp or one speaker breaks you still have three other bass channels working for your audience.
regards Andrew T. Last edited by AndrewT; 22nd March 2011 at 09:10 AM. |
| Melody 400W Power Amplifier | Ermac | Solid State | 41 | 13th February 2012 10:59 AM |
| 400W Power Amplifier | AraNubanti | Solid State | 18 | 8th November 2009 11:28 PM |
| NX400 - 400W RMS@4Ohms Lateral Mosfet Power Amplifier Module by Class-D for sale | magnum_1 | Swap Meet | 16 | 13th June 2009 03:59 PM |
| power amplifier 400w @ 4 ohms | divojara | Solid State | 8 | 22nd June 2007 06:54 AM |
| Yamaha Power amplifier 400w $220 | priscared | Swap Meet | 1 | 12th July 2004 11:57 AM |
| Page generated in 0.08920 seconds (71.37% PHP - 28.63% MySQL) with 10 queries |
