Old 26th November 2007, 01:13 AM   #1
adason is offline adason  United States
adason's Avatar
Default 3-5 watts classA amp
I was bored over the holidays so I made small amp. Just for fun. From spare parts. Its from this site:
http://www.redcircuits.com/Page80.htm
Sounds good. Definitely worth exploring.
ed
Old 26th November 2007, 01:43 AM   #2
This amp is similar to the JLH Class A amp.
http://www.tcaas.btinternet.co.uk/jlh1969.pdf
Old 26th November 2007, 08:18 PM   #3
Minion is offline Minion  Canada
Hi, I have looked at that circuit before but never got arround to Trying it because I have had problems with many of the circuits on that site.....But now that i know someone else has tried it I am more inclined to build it.....
I just quickly did up a PCB design for this amp and was wondering if someone could look at it and see if I made any Mistakes....
I used the Pinout for the Output transistors after the Tip transistors as that is what I have on hand (B,C,E) and I used the pinout for the other Transistors as a BC560 which I have...
The PCB is 2in x2.1in....
Thanx
PS, I also used an Input resistor for the P1 pot to set the Input impedance...
Old 26th November 2007, 08:23 PM   #4
adason's Avatar
I just want to add one more information. Amp prefers regulated supply. It works with both just fine, but you need way too much capacitance for unregulated supply to be hum free. Than it kinds of defeats the purpose of cheap amp, does not it, if you have to use tons of filtration.
ed
Old 26th November 2007, 08:55 PM   #5
Filtration is cheap.....I have a Box full of 10,000uf caps that I got for $1 each, also with a LM317 regulator and a cheapo Pass transistor you can make a regulated supply that supplies serveral amps of Current.....
Old 27th November 2007, 12:08 AM   #6
adason's Avatar
yes and no....
I was testing unregulated suply, started with one 27000 uF, big hum, obviously its simple classA amp, that is expected. I needed to add six (6) of those 27000 uF caps. Now that is not a cheap solution.
On the other hand, if you use just 5000 uF before, than regulator, and 1000 uF on the output, it will be much less money.
ed
Old 27th November 2007, 12:12 AM   #7
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
or 27KuF , then cap multiplier , then 27KuF
that's even better than reg
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 27th November 2007, 12:22 AM   #8
adason's Avatar
Hi Choky,
that would increase voltage. I started with the voltage I wanted, 22-24 V. Just wanted to filter it.
By the way, when you use multiplier, does not that reduce current capability? You know, each time you double the voltage, you half the current?
This amp takes 1.5A.
ed
Old 27th November 2007, 12:29 AM   #9
Zen Mod's Avatar
Originally posted by adason
Hi Choky,
ed
not voltage multiplier ;
cap multiplier .......... google for it or go to ESP site and read tutorial
Old 27th November 2007, 12:37 AM   #10
adason's Avatar
I see, Choky, great. I was in Elliotts page. I got it.
ed
Bootstrapped ClassA - ? Bigun Solid State 24 28th August 2009 02:20 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
ClassA, how does it work? lumanauw Class D 6 11th March 2008 10:33 AM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Page generated in 0.10390 seconds (78.54% PHP - 21.46% MySQL) with 11 queries
