| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Thread Tools |
I was reading another forum and found an interesting subject discussing opamps used for unity gain. The general comments were opamps when used for unity gain sound bad. The possible cause, I guess, is the largest amount of feedback used. Note that I am only talking about using unity-gain-stable opamps. I use opamps in active crossover network. Shallen key is common place. So, is this right? Does it mean we should always add some gains, despite higher noise? High frequency gain or low frequency gain? How much gain? Would it make the opamp clip easily? Any opamps that sound the best for unity gain buffers? opa627, opa2134? ad825? What is your solution to this? Regards, Bill |
#2 | |
#3 |
I'd say th e comments about stability ar e valid in many cases . . . . but then read the app note and take th e necessary precautions to prevent oscillation/misbehaviour:-
Dont operate non-unity gain stable op-amps at gains lower than specified by the manufacturer Make sure you isolate capacivie loads adequately - these can cause a pole in the op-amps response and this leads to instability Decouple thoroughly and close to th e op-amp Make sure your grounds are clean and are low inductance For summing circuits (or non-inverting feedback nodes), place the feedback resistors AS CLOSE TO THE INVERTING INPUT PIN AS POSSIBLE. I've seen this rule broken many times and always with the same results - noise, EMC pickup, instability Finally, to all those people that complain about th e 'op-amp' sound, remember next time you listen to one of your favourite CD's (or maybe vinyl recording) that the signal chain from mike through to cutting head has almost certainly gone through about quite a few op-amps along the way. Welcome to the 'op-amp' sound! |
#4 | |
Unity gain op-amps used in high gain circuits do not sound so good. Non-unity gain op-amps used at unity gain oscillate, not too good. The idea that high gain op-amps "slugged" for unity gain sound poor is somewhat of a fallacy but an advanced, (compared to the normal 6dB/octave scheme), 12dB/octave compensation scheme can improve high frequencies (y filters) by maintaining internal loop gain and consequently feedback factor at high frequencies. The same is true for audio gain stages ...... Quote:
true is stabililty is marginal and improved by higher gain. As an idea it is overly simplistic as the "amount of feeddback" i.e. the feedback factor is largely constant for a given stability. By increasing gain and reducing feedback factor (increasing stability) distortion is increased. Unless of course the op-amp sounds fabulous with the lowest possible feedback, i.e. max gain and attenuating the output for your required gain. /sreten.
#5 | |
When one amplifier is nearly perfect (technically), the sound is said "dull, dead, thin, bad". When there's another amp that has a not so good clipping behavior plus quite high harmonic distortion (2nd, 3rd), the sound is said "good". Chipamp with PS cap only nF (while the manual suggest about 1000uf/more) and omits the zobel stabilisator is said "very realistic", but I'm afraid that there's a marginally oscilation threshold and the PS junk is actually entering the sound. Confusing for me
#6 | |
Tetsujin
I know, I know, it's a dull way to look at things, but wouldn't it be useful if, in subjective evaluation, people stopped talking about a box of gain "sounding good" or "sounding bad," but instead talked about whether or not the output sounded like the input?
"We all feel like that, Reggie, now and then, especially when Spring is upon us, but few of us would care to put it on our cards." — Sir Archibald Clerk-Kerr |
#7 |
I didn't want to offer the "boring" view, but I just can't help myself any longer ;-) It baffles me why people think they can just pop one of a dozen opamps into a circuit, then listen and declare they know something about the way opamps sound. Where is it written that all those opamps operate at their best in the same circuit? Why do people think all those different opamps exist in the first place? Sometimes the tests are done without a scope, often without a schematic or knowledge of the actual circuit configuration (typically in CD players). "Rolling" opamps is a joke. IMO, almost any of the popular high performance opamps can be stabilized and configured to be indistinguishable in audio applications, if they have sufficient gain bandwidth product, low distortion, and aren't asked to deliver excessive output current or drive an unsuitable load. IMO, opamps are viewed as really simple to use, and the truth is that a certain amount of knowledge and skill is required to get the most out of 'em.
#8 |
Electrons are yellow
Conrad, your thoughts are always in my mind but I have long time stopped arguing about it.
Picture this: Not 100% good recording => MP3 coded => average sound card or even bad => not optimal pcb in general and not in particular for the opamp => bad or average headphones This is a common setup to judge the characteristics of an opamp.
/Per-Anders (my first name) or P-A as my friends call me BPA300 Group Buy Round 4, SMD-kit and DRV134 pcb. Not too late to sign up. Sign up HERE |
#9 | |
Hi, SY,
![]() What makes me confuse is I like the sound of those "faulty" amps. When I tweaked both the "not so good clipping behavior plus quite high harmonic distortion (2nd, 3rd)" and "Chipamp with PS cap only nF (while the manual suggest about 1000uf/more) and omits the zobel stabilisator" to meet the technical POV, ie: stable towards R//C load, have the best square wave response and best residual (in my distortion meter+scope), the sound becomes "worse". (oops..sorry, I use this kind of term again )
#10 |
NFB is not the cause of 'sound' differences in unity gain op-amps.
whether 120dB of NFB or 130 dB NFB wont matter to the sound. Stability may be an issue. |
| Thread Tools | |
| Unity Gain op amp circuit? | jetbat | Solid State | 3 | 5th May 2009 12:29 AM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| Unity Gain (AV=1) Zen Amp | LS | Pass Labs | 2 | 16th September 2004 04:40 AM |
| Unity Gain Operation (or low gain) | Tomo | Chip Amps | 12 | 22nd January 2004 01:47 AM |
| Page generated in 0.12539506 seconds (81.42% PHP - 18.58% MySQL) with 11 queries |
