#11 |
627 is fine at unity gain.
#12 |
AD797 - properly implemented, it's the best sounding opamp in unity gain configuration (chosen among 20-30 most popular and best specified opamps made by TI, Analog, Linear).
It even sounds better than many discrete buffers. Don't worry too much about NFB. It's not good or bad by itself , it will just reveal topology behind it. http://www.diyaudio.com/forums/showt...927#post980927 |
#13 |
The AD797 is UNSTABLE at unity gain.
#14 |
Of course, you can build a unity gain stable circuit with *any* opamp, regardless of its internal compensation. If I'm limited to two resistors and two bypass caps, then my options are a bit more limited ;-)
#15 |
You can make it "stable", but it is not the best way how to use the AD797.
#16 |
True enough, and it might not be my first choice for a unity gain buffer, though it can be forced to do the job. IMO, the 797 has a great data sheet, and op amp "rollers" would be wise to read it carefully. It ain't necessarily plug & play with a lot of other parts, unless you mod the circuit accordingly, which sort of makes my original point.
#17 | |
AD797 is absolutely stable at unity gain - I've built numerous circuits with it and there was no sign of instability at all. I don't wish any further argument on this subject - I'm talking out of experience, not waving with the paper. |
#18 |
Oh, Scott... Scott... Can you hear me?
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#19 |
Yes, Scott Wurcer is the man who designed AD797 and he is the member of diyaudio.
He might say a word or two about it
#20 |
Thanks, guys. Please keep your input coming and let us newbies be educated.
Yes, to me the comments I read from the other forum were more of a myth. I have used opa2134 mainly, most in unity gain and have not subjectively found any audible problem. I'd say the system is pretty much of high fidelity, although I must confess that opa627 was subjectively better in one of my experiments. So, is AD797 the best for unity gain? Juma, would you mind sharing on how to properly implement it? |
| Unity Gain op amp circuit? | jetbat | Solid State | 3 | 5th May 2009 01:29 AM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 02:30 PM |
| Unity Gain (AV=1) Zen Amp | LS | Pass Labs | 2 | 16th September 2004 05:40 AM |
| Unity Gain Operation (or low gain) | Tomo | Chip Amps | 12 | 22nd January 2004 02:47 AM |
| Page generated in 0.14432 seconds (58.33% PHP - 41.67% MySQL) with 11 queries |
