Old 26th February 2008, 04:43 PM   #71
PSU is 5 x 6800 uf (Elna LP5) per rail, using dual fullwave recifiers made from Hexfred diodes.
Near the end of the cap bank there are small inductors handwound around 3r3 resistors, at the end are 100nf wimas, then a snubber made from a 0r47 resistors and 1n5 caps.
All could be remove to just leave a standard setup but i though i would start with these in place and try removing each part to see how it effects the sound.
Phil
Old 26th February 2008, 05:20 PM   #72
Default sound?
Sorry to butt in here,
I was just considering weather to build up a second, more sophisticated LM3875 amp or get a a pair of these boards.
Any impressions on the sound? I have always liked the Naim sound but I thought my dual-mono LM3875 sounded better than my friend's old NAP110.
Anyone have a finished build they would care to review here?
Old 26th February 2008, 05:27 PM   #73
I have had them up and running and also have a few LM based amps. The chippamp.com Lm3886 and the My Ref C design as well.
In the next few days they should be finished and replace the gainclone and them we will see. The one issue is mine are the Avondale ncc200 copies rather than the straight Nap140 boards that they now sell so it won't be strictly comparable. I would however hope that a well built and pair of either with a decent psu could top the gainclones, else i won't have bothered!!
Old 26th February 2008, 05:47 PM   #74
brianuk is offline brianuk  United Kingdom
Phil,
Loooking very good, credit to you.
Gives a pic of the underside of the PSU. Only thing you might change is to make it dual mono - but you could do that if you think its heading where you like it.
Nice one,
Brian
Old 26th February 2008, 05:58 PM   #75
To be honest your probably right about the dual mono being a better idea, but the caps came as a lot of 10 from ebay so i either lost a couple and went like that or did a mono psu with 68,000 uf. Plus i had the option of one pretty good tranny or 2 less good ones. Its the start of the year, I am self employed so what with the tax man i am skint.
Hopefully the high capacitance and 500va should keep it pretty stiff anyway.
Here the board layout and thanks for the support.
Phil
Old 26th February 2008, 06:00 PM   #76
Any suggestions on layout as well, recon shorter leads would be better than the heatsink as a barrier?
Old 26th February 2008, 06:04 PM   #77
No thanks needed, I havent helped that much, more encouragement.
One big tranny can often be better than two small ones, only two big ones win
Its going to be a top notch amp on budget, psu looks good, did you calculate the inductor off the web calculator?
Whats the gauge of the enamelled wire?
Nice job on the DIY board, wish I could do that.
Old 26th February 2008, 06:09 PM   #78
I'd go with whats easier to wire, I believe its the vertical direction you worry about most with Toroidals (ie the next component above seperated by a few inches), though could be correct.
As long as theres some space I'd go with easy to build any time, shortest returns from speaker to caps. Ie put the toroid at the front if you can so the speaker returns get back to the cap with least resistance.
Old 26th February 2008, 06:15 PM   #79
To be honest its a bit of a pick n mix PSU nicking all the stuff i have used and or heard about.
The snubber network seems to be a pretty standard setup used on a lot of DIYaudio boards since CarlosFM came up with it for the LM3886 based gainclones. Seem it used on several other setups.
The inductor setup is based on the DXamp which i have been keeping an eye on. Its also uses the same snubber network values. The board is very heavily built so i can unsolder stuff at will and short them out to see if that changes things for the better.
My pcb layout skills aint bad but the psu is in truth a bastard child of many things. Mainly cos i cant work out that Duncan amp PSU simulator for toffee, i studied at art college instead of continuing electronics unfortunately.
We will see.
You should try something like Eagle PCB software though, i built my first pcb in about a day using it.
Old 26th February 2008, 06:19 PM   #80
Regarding toroid noise, why not just a plat across to shield?
I assume you are taking all the 0V back to the cap board as a star?
GB - F5 Clone suds Group Buys 3 23rd August 2010 01:03 PM
Tube Preamp 'Clone' PCB copys on ebay (Marantz, McIntosh, etc) powertriode Tubes / Valves 57 11th August 2007 07:59 PM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 08:19 PM
Copyright ©1999-2013 diyAudio
