NAP-140 Clone Amp Kit on Ebay
Old 24th February 2010, 05:44 AM   #501
marcel5996 is offline marcel5996  United States
Hi Gaborbela, thanks for the answer. I read about the differential HFE. I have two issues though 1) I'm not sure how to measure hfe with a dmm. 2) I hate to mess around with the board, desoldering transistors since it actually works and sounds very nice. Is there anything else that can be done? (adding cap at the output?). Is 63-69mv abnormal and too much for the speaker drivers?
Old 24th February 2010, 06:13 AM   #502
Ruwe is offline Ruwe  Europe
IMO, 65mV is not that much. If you like values closer to 0mV, the input transistors have to be hfe matched.
Avondale recommends T1 hfe to be 10% bigger than T2, which is beneficial for the balance with audio signals (less distortion), but will spoil a little bit the 0mV output. May be that's what happened when you replaced the transistors. I guess the first pair was better matched, even though unintentionally.
Also the input resistors combination must be equal (or very close) to the 27k that's in the feedback path. You can tweak the values slightly for better results. For example instead of 24k+2.7k you could use 24k+3k. It's easier to replace a resistor than a transistor.
Regards.
Old 24th February 2010, 06:23 AM   #503
Thanks Ruwe, you always get to the point. That's exactly what I was looking for. Replacing a resistor worries me less than a three-lead transistor! When I feel courageous enough, will try the supplied BC550, to see if they're better matched
Old 24th February 2010, 06:50 AM   #504
gaborbela is offline gaborbela  Canada
Default I'm not sure how to measure hfe with a dmm.
Hello
That is the problem !
You must match those two transistors as close as possible . Matching the LTP can improve the sound also (a little bit)
Do not use capacitors on the output !!
Actually if you like the sound you can leave it how is it . That offset is acceptable .
Just check the offset after the amplifier warm up . If the offset increase that would be a bigger problem .
On your DMM here is some small holes and marked PNP & NPN that is for measure the transistors hFE .
Some transistor PNP & some NPN , U have to use those holes which category the transistor belong . You can find the transistor info on the net .
For exam. BC546B Data , and you can get the information if is PNP or NPN .
Please do not be afraid , you can not damage the transistor while U measure the hFE .
I dont know what type of DMM you have .
Most DMM has access to measure transistor hFE .
Greets
Old 24th February 2010, 02:19 PM   #505
juluska is offline juluska  Ukraine
photos of my amplifier just completed:
ignatius little projects
Old 24th February 2010, 04:34 PM   #506
kclusa@yahoo.co is offline kclusa@yahoo.co  United States
Default Nice NAP140
I notice that the Q5 did not attach to heat sink. In summer, at loud volume, the power transistor could heat up very quick and destroy itself. It is called thermal-run-away.
Just my observation.
Lou
Old 24th February 2010, 05:47 PM   #507
Lou
I've tested it for hours at high volumes (high enough to go deaf) with DJ sessions without heating problems in q5. I appreciate the advise, this summer I will observe how it behaves.
Old 24th February 2010, 06:46 PM   #508
2Bak is offline 2Bak  Denmark
Good looking amp. Nice implementation of potentiometer and input selector at the rear.
How does it sound?
Old 24th February 2010, 06:55 PM   #509
Default Q5
Sorry, I was not making it clear.
Q5 is responsible to bias 2sc5200 and TIP transistor and if heat sink temperature rise, Q5 will sense the heat, and Q5 Vce will drop and reduce the current of these 4 transistors.
Q5 will ensure thermal stability of these 4 transistors.
Q5 itself wil never over heat.
Lou
Old 24th February 2010, 07:21 PM   #510
How does it sound?
It sounds very well, very correct amplifier.
NAP-140 Clone Amp Kit on EbayHide this!Advertise here!
GB - F5 Clone suds Group Buys 3 23rd August 2010 02:03 PM
Tube Preamp 'Clone' PCB copys on ebay (Marantz, McIntosh, etc) powertriode Tubes / Valves 57 11th August 2007 08:59 PM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 09:19 PM
