NAP-140 Clone Amp Kit on Ebay
Old 16th January 2008, 01:21 AM   #31
DreadPirate is offline DreadPirate  United States
DreadPirate's Avatar
I lost my copy of the Chinese insert that came with this kit. If someone would kindly post, I'll pass it on to a co-worker who will translate it and I'll post it back.
Old 16th January 2008, 10:50 PM   #32
The kit comes with this instruction sheet/parts list and the schematic previously posted. I'll look into getting this translated.
Old 17th January 2008, 04:42 AM   #33
al2002 is offline al2002  India
al2002's Avatar
Is the output stage protection circuit included in this implementation? There are NAIM clone boards out there that leave it out.
Old 17th January 2008, 07:06 PM   #34
This second instruction sheet recommends addition of speaker protection. The kit does not include it.
Old 27th January 2008, 08:55 PM   #35
Flappytango is offline Flappytango  United States
I am planning on getting one of these kits off ebay.. I want to build something to power my recently finished Usher 701's (parts express kit but my own cabinents).
Can anyone point me in the direction or recomend a good power supply design suitable for this amp kit??
Thanks in advance.
Old 30th January 2008, 11:42 AM   #36
Well i ordered one of the 'improved' NAP140 kits they now have on ebay. The layout looks to have changed a bit and the board is white.
http://cgi.ebay.co.uk/IMPROVED-POWER...sid=p1638.m122
Any help with power supply designs?? My only amp building experience is with a briangt chip amp. I could use some advice.
Old 30th January 2008, 02:56 PM   #37
rocky99 is offline rocky99  United Kingdom
Flappy
Here is an article on a simple Power Supply that will get you going:
http://sound.westhost.com/psu-wiring.htm
Good luck.
Old 30th January 2008, 04:50 PM   #38
Thanks Rocky99,
so it looks like a simple power supply will do the trick...
I want to order some parts so ill guess ill go with the same rectifier (mur860 diodes) and general circuitry as i built for my chipamp specifically this design
http://chipamp.com/images/ps.gif
but i will probably bring up the capacitance a bit with multiple filter caps
Old 5th February 2008, 11:21 AM   #39
filholder is offline filholder  United Kingdom
OK i have built my boards what is the next step?
I have found a couple of huge Erie 22000 uf caps and a pair of decent metal cases diode bridges, with a spare 300 va daul secondary tranny this should make an ok basic psu.
However i dont know how i should start to test these things, where the connections go or indeed how to start biasing them.
Any help gratefully recieved.
Phil
Old 6th February 2008, 01:02 PM   #40
Dave S is offline Dave S  United Kingdom
Anyone care to comment on the suitability of TIP41C/42C as drivers. The gain and (therefore) GB product is rather low compared to the parts Naim use. Cob is also 2X the Naim parts, I wonder if this mucks up the frequency compensation (base resistors and RC in parallel)?
The VAS Tr is a 2SD667 - this looks OK to me.
NAP-140 Clone Amp Kit on EbayHide this!Advertise here!
GB - F5 Clone suds Group Buys 3 23rd August 2010 01:03 PM
Tube Preamp 'Clone' PCB copys on ebay (Marantz, McIntosh, etc) powertriode Tubes / Valves 57 11th August 2007 07:59 PM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 08:19 PM
