#361 |
I've used this circuit (42.5) for awhile, because I thought it would have been a good match with the 140 clone. It's a simple and very cheap preamp, nothing special. I didn't buy the kit, just made it on a prototype board. Will work fine and will have a pretty high gain, that you won't need with the 140 - about x10 if I recall correctly. I switched to N. Pass preamps, though. The 42.5 changed the sound somewhat which is not my idea of a good preamp. I'd prefer to not hear the preamp in the system and the Pass ones are nearly perfect in this domain. This kit looks very well made, so it may be also better sounding than mine prototype. |
#362 |
Hi marcel5996,
Finally you found it. This explains your blowing protection resistor on the power supply line. I think this amp will work normally at 2x47V. Capacitors are usually conservatively rated, so they will be fine. Transistors should have enough reserve in Vce. I try to use transistors rated at least twice the supply rail they are connected to. For example, for 2x47V I would look for transistors having Vce=100V minimum. I would do same with the capacitors but it's too expensive and bulky. The reason is that in extreme conditions, during failures of some components, some transistors may see the whole voltage across them. They are very easy to blow, even for fraction of a second of overvoltage. I don't like regulated power supplies in amps, but it's just my biased opinion. For separating the PS and the main boards: I would rectify the voltage close to the amp. Look at the national power grid shows that transporting AC is more common. I don't think it matters in audio, but anyway. Also, if you use the point between the capacitors as a star ground point (and you should), they have to be closer to the amp boards. If you decide to transport 2xAC + center tap, I'd recommend using a cable having 3 conductors and a shielding. You can connect one side of the shield to one of the boxes (usually to the output box, in your case the box with the transformer inside). The shield is to prevent picking hi-frequency interference noise, cables are also sort of radio antennas. The transformers are intrinsically decent RMI filters, and you don't want RMI picked again after your transformer. If you need better power line noise suppression then you should use an isolation transformer and to connect your whole audio system after. I found this better solution than any EMI/RMI passive filters etc., but I've never tried AC regeneration devices which are very expensive. Hope this may help. Regards |
#363 | |
#364 |
You can transport DC or AC. I don't think it matters very much, especially for 50 cm. Just a matter of ease to apply. Yes, if you use two secondaries and dual rectifier, then use 4 wire + shield if you can find such a cable. There should be some on the electrical market. Or use 2 cables, one for each rectifier. If you don't have any other way to ground the case of the amp you can definitely use the shield to transfer the earthing between the boxes. Just find a cable with good thick shielding. As about earthing the star ground, you should experiment. You may find that it's not necessary, especially if you have earthing elsewhere in the signal path. I wouldn't recommend DIN connectors. Use XLR connectors instead. There are many types and I've seen for sure a 4-pin one. XLRs are sturdier than DINs, I've read they are used in lighting installations and can handle 10A (Wikipedia). I am fan of XLRs! You don't need to buy anything expensive Neutrik-like. I personally bought for my Aleph1.7 pre some Chinese XLRs. They are locking together and are very well built for about 3-5$/ea, depending on the type - case mount or for cable. Contact-wise are much better than DINs. There is also a XLR standard for inputs and outputs, so you can check before, if you want to be compliant Although, I'm not sure there is any rule for non-standard voltage transfer, so you can use whatever combination you like or can fit as male-female pair.Regards |
#365 |
Banned
I just want to report back some results.
I have completed building one channel of this amp and have succesfully run it through a series of measurements using signal generator and cro. First up the only changes I made was to replace the input transistors to 2sc2240 and the output transistors to mjl4281. With this setup the amp ran beaurifully. I then decided to change the drivers from tip41c/42c to 2sa1837 and 2sc4793, however with these I got oscillation. My next variation (when the parts arrive) will be 2sc5171 and 2sa1930. So if you have used 2sc4793 and 2sa1837 as driver transistors and the amp does not sound so good then you probably have oscillation ocurring. Last edited by Melon Head; 8th September 2009 at 08:46 PM. Reason: spelling |
#366 |
Banned
I tested the amp with 2sc5171 and 2sa1930.
These also give oscillation. I was able to remove the oscillation by putting a 47pF cap across collector and base, however I am going to revert back to TIP41/42. |
#367 |
I bought the boards from Gigawork which included the Power Supply.
However i measure only about 20 Volt from Ground to either Positive or Negative. My Trafo has 30 Volt. Possibel the Power Supply is faulty? |
#368 |
#369 |
Hello
What is the maximum Power supply for the NAP 140 I have two toroidal 500VA 2x42v and 6x15000µf100v and i would like to use it ![]() ![]() Thanks Serge |
#370 |
Banned
I can't remember the reasons but +/-50V dc is as high as you want to go.
The recommended voltage is +/-40V dc |
| GB - F5 Clone | suds | Group Buys | 3 | 23rd August 2010 01:03 PM |
| Tube Preamp 'Clone' PCB copys on ebay (Marantz, McIntosh, etc) | powertriode | Tubes / Valves | 57 | 11th August 2007 07:59 PM |
| Question regarding ProAc 2.5 Clone and Tempo 2 Clone | zoooh | Multi-Way | 5 | 11th March 2003 08:19 PM |
