NAP-140 Clone Amp Kit on Ebay - Page 23 - diyAudio
Old 12th June 2008, 02:40 PM   #221
The former is based on the ncc220 from avondale audio, the latter is more based on the
nap140. Both are excellent amps by reputation, albeit I have never heard the ncc220
For the price, get both and then decide after some listening, thats my current plan.
best regards
cds
p.s. there is a thread on pinkfishmedia.net that covers this also.
Old 12th June 2008, 06:13 PM   #222
Default The beast lives!
After replacing the output transistors (using the Toshiba devices, does anyone know where to find the SanKens in the states?) Both boards are up and running.
Have them running off unregulated Dual-mono power supplies. 200va 25 volt torroids-- not ideal but I already had them-- rurp1560 rectifier diodes and Panasonic TSHA 10,000mf 63v filter caps.
Haven't made any direct comparison to either my tripath or LM3886 amps but I've been running it for about a week and a half and haven't been tempted to pull it out of the system. I take that as a good sign.
Quite enjoyable, really. Haven't tried any tweaking yet. It's good enough to live with as is for a while.
Old 21st June 2008, 05:09 AM   #223
Default Sanken transistor
HI
I have the original Sanken Power transistors 4PC if you are interested I can sell it to you for $20 plus shipping from Toronto .
I have the same kit but I use different tipe of power transistors .
These are brand new !
You can pay via pay pal .
Old 21st June 2008, 04:57 PM   #224
Default Capacitors
That is interesting. I didn't know TubesHunter still had the older NCC200 style boards for sale. I would have been more tempted to try a pair of those as I'm already quite familiar with the Naim sound but have never heard any of the Avondale products. People seem to speak well of the NCC200.
Anyhow, after giving the boards a few weeks to burn in I started to become intensely bored with listening to music. I just felt so far away from the performances. Not being sure if it was the new amp or my mood, I swapped in my LM3886 amp and POW! Music! I was so relieved to hear music again. Having owned a few Naim amps in the past I know that one thing they are not is boring. BUt this amp was merely making sounds-- not music. No pace, no timing, no real dynamics. So I decided to open the thing up again and mess around.
The biggest difference-- and I would highly recommend that anyone with the blue board version try this-- was to get rid of all the SILMICs. I was suspect of them as I have tried them in other projects and always thought they ruined the fun. Replace the 100uf caps with Panasonic FC and all the 10uf decoupling caps with solid Tantalum caps (ala Naim)-- the tantalums are not cheap (about a $1.60) but the bloby yellow beasts work very well in this position. Here is a link to the digikey listing:
http://search.digikey.com/scripts/Dk...me=399-3579-ND
After the capacitor change the amp sounds very good, much better than the GC. And I have MUSIC again! Rhythm, detail, life and I feel much closer to the performances again. Definitely worth a few bucks and a few minutes worth of work.
Old 21st June 2008, 05:19 PM   #225
traderbam's Avatar
I am glad you've managed to change some parts and make it sound good.
I have a trades descriptions axe to grind about these so-called "clones" because they are nothing like the thing they purport to replicate.
The schematics are similar (not the same as Naim's) but the parts are significantly different in that the Naim requires carefully chosen values for things. This is because the Naim circuit is a high feedback design and is very sensitive to individual part tuning and layout and psu and wiring. I'm not convinced Avondale know what they are doing either.
So it is going to be a bit of a lottery how good each kit sounds when it is built. NONE of them will sound as good as a real Naim circuit.
The good news is you save money and enjoy the diy process.
Old 1st July 2008, 03:02 AM   #226
I wish I had a NAP140 to reference. There was a day (I don't miss those days) when I worked for a Naim retailer and had laods of gear for reference. Alas.
It does need some major fiddling. Right now it sounds decent--almost like music-- but it could definitely use more work. For the time being I think it's fine but, I'm rethinking PS and ground choices I made. Perhaps a more traditional Naim-like PS with half-wave bridges and center tap toroids would be better? And maybe moving the 0v point from the PS to a bar between the speaker grounds?
One way to find out I suppose...
Old 20th July 2008, 01:04 PM   #227
Banned
Default nap 140 clone vs JLH 30W per channel
I am interested in this NAP 140 clone however I am wondering how it might stack up against the JLH Class A amplifier.
Should I just build the JLH Class A amplifier or is this NAP 140 clone better?
Thanks for any advice?
Old 23rd July 2008, 09:36 PM   #228
Default Help please
Hi, i have just built a pair of these power amps, my first go at building amps.
I have built 3 power supplies 2 of which did not work but the 3rd seems to work,so of i went to check the amps.
My problem is when i wire one amp up, no speaker connected, i try and set the VR up but i get no volts at all.
There was no bang or smoke when i wired it up so thats not bad?
While i had power on i checked for voltage which i get from the speaker out put but its 40v.
I have also checked my other amp i have built and that is the same,i touched the out put trans and they were cold to touch and the board was not warm when i touched with my hand.
I have read all the posts and there is none with my fault so i cant go and check if i have a fault or i have built it wrong.
I have also checked the ground as was said in one of the posts and that is ok.
Any help or advice would be helpfull or do i bin them?
George.
Old 23rd July 2008, 10:48 PM   #229
traderbam's Avatar
It won't hurt to shamelessly copy Naim. I'll be happy to comment on your grounding and psu and so on if you email me. The Naim's I've seen, like the 250, use dual secondary xformers and two full-wave bridge rectifiers. Like making two separate dc supplies and then connecting them in series to form a - 0 + supply. The star ground is best located near the psu caps to minimize the noisy wiring runs.
Old 24th July 2008, 06:12 AM   #230
Greg Erskine's Avatar
Default Re: Help please
George.
Have you connected signal ground to star ground?
Greg Erskine
GB - F5 Clone suds Group Buys 3 23rd August 2010 01:03 PM
Tube Preamp 'Clone' PCB copys on ebay (Marantz, McIntosh, etc) powertriode Tubes / Valves 57 11th August 2007 07:59 PM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 08:19 PM
Copyright 1999-2017 diyAudio
