High quality 40-60w amplifier
Old 23rd November 2007, 01:47 PM   #1
geminni is offline geminni  Serbia
Default High quality 40-60w amplifier
I have a bunch of a BD911 and BD912, had full of BC-s, and transformer with 2x20v ac. That gives about 2x40w at 6 ohm. I have tried to find schematic for this kind voltage but found couple of "no name" type schematics.
Can anyone suggest some fairy simple schematic for 2x28V but some good quality amp?
I'll try to find schematic that i have made but I'm not pleased with it because it's midrange is very bad sounding
Also, i must say that, building amp with Lm3886 and similar maybe is faster but it takes away all the fun of building one
Old 23rd November 2007, 03:06 PM   #2
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
Elliot P3A or any Lin-Bailey Class AB/B variant, like the Elektor Darlington amplifier from 1982 by T. Giesberts. This topology gives excellent performance, while leaving a lot of room for sonic tweaking, a la Hugh Dean's AKSA and its higher-end upgrades.
Old 23rd November 2007, 03:16 PM   #3
Twaksak is offline Twaksak  South Africa
Twaksak's Avatar
How about the bameless amp from Self. If I had components laying around that would be interesting for me. All types of distortions cancelled out as per Douglas Self. A very clear and precise amplifier indeed.
Old 23rd November 2007, 03:29 PM   #4
Donk is offline Donk  Europe
Donk's Avatar
My 50W/4Ohm 30W/8Ohm error-correction amplifier design using dirty cheap parts.
Your 2*20Vac transformer will be just OK. Use 10.000uF-35/50V elkos for PSU.
Old 23rd November 2007, 03:31 PM   #5
Donk's Avatar
PCB (non-mirrored!)
http://forum.audiodiy.hu/download.php?id=2059
Old 23rd November 2007, 03:35 PM   #6
Donk's Avatar
Placing
Green lines are wire links, blue line is the heatsink of BD139
http://forum.audiodiy.hu/download.php?id=2058
2.2uH coil is air-cored, 23 turns of D=1mm enamelled cooper wire, on 10mm former, length is 24mm
Amp performance: THD and IMD <0.01%, ...50W, 20Hz...20kHz
Old 23rd November 2007, 07:08 PM   #7
Wow! Thanks guys!
Now i don't know which to do first
Old 24th November 2007, 01:01 AM   #8
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, Donk,
I'm very interested in your CCT, but unfortunately I don't understand it. How does your EC work?
Old 24th November 2007, 10:39 AM   #9
pintur is offline pintur  Italy
Very nice, Donk.
It seems to be inspired to Quad 405' s current-dumping topology.
Old 25th November 2007, 12:26 PM   #10
Donk's Avatar
Hi guys,
Lumanauw, see the following links for working method of my amplifier:
http://www.google.com/patents?id=t6I...BAJ&dq=3970953
http://forum.audiodiy.hu/files/ec50_m_460.jpg
Be careful, the attached schematic is only a test version, a prototype, It's not a final version!
There is a fault in the circuit and on the PCB-placing: the three 1N4148s in serial need to be three 1N4002s in serial!!!
High quality 40-60w amplifierHide this!Advertise here!
JLH Direct-Coupled High Quality Stereo Amplifier kimbo Solid State 104 6th July 2014 03:29 PM
Help with amplifier design (high quality) CrazyChipMan Solid State 20 10th July 2012 07:25 PM
High Quality mic amplifier for Panasonic WM-60a electret? Toster Solid State 8 10th March 2004 06:29 PM
Copyright ©1999-2017 diyAudio
