Old 22nd November 2007, 10:55 AM   #1
Onvinyl's Avatar
Default Spice for beginners?
In the 'permanent' spice thread, someone suggests a 'basic spice' course or wiki. Does something like this exist here?
For the moment, I have a RC-loaded circuit the distorts heavily where I thought it wouldn't *and* one that behaves well where I thought it shouldn't work [neat|at all].
I guess I'm not the only one...
What I have in mind are some kind of 'standard treatments' in very basic circuits (high and low pass, 1-Q-followers or -gain blocks and the like).
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 22nd November 2007, 11:33 AM   #2
nice idea
regards Andrew T.
Old 22nd November 2007, 12:36 PM   #3
MJL21193's Avatar
That's a very good idea. I like it.
Old 22nd November 2007, 01:13 PM   #4
PigletsDad's Avatar
See http://newton.ex.ac.uk/teaching/CDHW...cs2/userguide/
There are some examples, I think in one of the appendices.
Old 23rd November 2007, 10:15 AM   #5
Onvinyl's Avatar
May I present a problem which should lead us to some basic RC-treatments?
Beneath is a riaa network(, fed by an ideal sine wave and inversed and 'gained' by an ideal inverter/amplifier.
A distortion measurement as displayed gives me a THD of 3.56%!
This method is given by Klaus (KSTR here) and gives reasonable numbers for a bunch of well documented circuits I tried.
As I think, that an 'ideal' phono pre shouldn't distort that much, there should be mistakes in this setup.
Which?
Rüdiger
Old 23rd November 2007, 11:12 AM   #6
KSTR is offline KSTR  Germany
KSTR's Avatar
A reported "problem", see
http://www.diyaudio.com/forums/showt...19#post1246419
And the user manual reads:
"The transfer function of this circuit element is specified by its Laplace transform. The Laplace transform must be a function of s. The frequency response at frequency f is found by substituting s with sqrt(-1)*2*pi*f. The time-domain behavior is found from the impulse response, which is found from the Fourier transform of the frequency-domain response. LTspice must guess an appropriate frequency range and resolution. The response must drop at high frequencies or an error is reported. It is recommended that the LTspice first be allowed to make a guess at this and then check the accuracy by reducing reltol or explicitly setting nfft and window. The reciprocal of the value of window is the frequency resolution. The value of nfft times this resolution is the highest frequency considered."
In reality (within the simming context), you don't have any distortion in the time domain, because both the laplace and the passive components are LTI (linear time-invariant). One can model nonlinear caps and resistors, though.
- Klaus
Old 23rd November 2007, 11:32 AM   #7
Onvinyl's Avatar
Hi Klaus,
thanks for your answer.
I have to admit, though, that I'm completly lost here.
Are you saying that I shouldn't get the THD-numbers I quoted? Or that I should ignore them? Then the word 'problem' shouldn't go with quotes because any analog filter circuits can't easily be tweaked.
thanks,
Rüdiger
Old 23rd November 2007, 12:00 PM   #8
PigletsDad's Avatar
There should be no THD.
Your problem is that you have not allowed any settling time, so the output waveform is distorted by the initial charging transients.
Accurate simulations require the use of extra start time parameter in the .tran card.
Old 23rd November 2007, 12:04 PM   #9
KSTR's Avatar
Rüdiger,
Yes, you should get a straight zero for THD, because all elements are linear with regard to voltage and current. More precisly, you get the generator's intrinsic distortion multiplied with gain error at the harmonic frequencies. Say you input is 1kHz with a -90dB H2 component and your frequency response error is -1dB at 1kHz -3dB at 2kHz, H2 would come out as -92dB. But the generator distortion is really low, <= -160dB when using a small max timestep.
The errors you see come from the problems of doing the Laplace transform in the time domain, in LTSpice. Seems that one can't use it at all or has to know all the guru tweaks to get reasonable results (I don't).
Dad also raised a point... so try that first, let it run for like 20 cycles and then .four the last ot these (which it does by default).
- Klaus
Old 23rd November 2007, 01:11 PM   #10
Onvinyl's Avatar
Well, ok, seems I should read the error log as such as well...
"Frequency response of Laplace device "E1" does not roll-off fast enoughLaplace source: E1
WARNING: This Laplace expression needs an additional delay of 23.2µs to not violate causality.
Freq Domain: peak @ 0Hz BW=0Hz cutoff @ 0Hz
resolution: 250Hz nfft=16384
Time Domain: window=0.00196045s resolution: 2.44141e-007s
Second Compression Ratio=422.632
I altered the tran command to
.tran 0 {10*(ncycles*period)} 0 {pi/3.14*period/2e3}
this gives me a thd of .055%.
With
.tran 0 {20*(ncycles*period)} 0 {pi/3.14*period/2e3}
I get 0.022%.
The command
.tran 0 {100*(ncycles*period)} {99*(ncycles*period)} {pi/3.14*period/2e3}
gives .000134%
the same as
.tran 0 {100*(ncycles*period)} 0 {pi/3.14*period/2e3} to check if the simulator really choses the last cycle(s).
So, if one has the time (ran ~ 10minutes on my 2.4 GHz (or the like) PC it is at least usable to see if your circuit develops issues with one's RC- network.
Thanks!
Rüdiger
Free Spice Or Cheap Spice Simulator-Where To Start? kelticwizard Everything Else 29 15th February 2007 01:38 AM
F2 for beginners vitalstates Pass Labs 6 24th January 2007 12:02 AM
beginners q's lt cdr data Solid State 3 23rd May 2005 09:59 PM
Page generated in 0.12354 seconds (79.67% PHP - 20.33% MySQL) with 11 queries
