Antiphase wired second transformer in a 65-0-65 PSU to reduce ripple
Old 16th February 2003, 02:39 PM   #1
the toasted is offline the toasted  Germany
Question Antiphase wired second transformer in a 65-0-65 PSU to reduce ripple
Hi everybody!
What I want to do ist to reduce the current ripple in my 65V-0V-65V (5A-0-5A) PSU.
It is based on:
2x block transformer (230V/46V 320VA)
8x 4700myF/100V electrolytic filter capacitors
2x 700V/35A metall bridge rectifier
4x 10myF MKP capacitors (2 per rail)
and 2 4k7/10W resistors
I use it to power my 2x150W A/B solid state power amplifier.
My question is:
Can I reduce the ripple current by wireing the second transformer antiphase so that the maximum + of the one trafo is at the same time than the max - of the other trafo?
I thought, that this would smooth the ripple at the end of the PSU and give a cleaner voltage for the amp.
Is this right? Please give me your suggestions!
Thanks,
the toasted
Old 16th February 2003, 02:53 PM   #2
megajocke is offline megajocke  Sweden
megajocke's Avatar
How are they connected? Do you use one for plus and one for minus, or are they connected in series? If you use one transformer for minus and the other for plus it won't make a differece as the circuit is symmetrical.
If you use it with center tap (but you said 2 rectifiers so I guess not) then they should be connected so that the ends of the windings are in anti-phase.
Old 17th February 2003, 01:20 PM   #3
k.junold is offline k.junold
Default Thanks!
I use them with center tap -> so you wrote what I wanted to know! Sorry for my bad explanation.
I use two rectifiers (like in a circuit of Anthony Holton http://www.aussieamplifiers.com ).
Thanks for your help!
Old 17th February 2003, 07:48 PM   #4
megajocke's Avatar
is it this one? It looks like the author got some kind of brain fart there??? If you trace from the bottom end of the transformer, going through two forward biased diodes you end up at the other end! Could you please explain (or draw) your configuration...
Or have you connected the center tap to 0V and use one bridge per channel?
Old 17th February 2003, 08:28 PM   #5
On Hiatus
SY's Avatar
4700 uF is mighty skimpy for a 150 W amp. The best thing you could do is to take that up to 20,000 uF or so. That will take your ripple below audibility.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 18th February 2003, 12:56 PM   #6
megajocke's Avatar
He says he has eight of them. That's 18800F per rail.
Old 18th February 2003, 02:13 PM   #7
On Hiatus
SY's Avatar
I misinterpreted; I thought that he had two rails, two channels. If he's got 10-20KuF, his question should be, why do I have any significant ripple in the first place? Grounding problems?
Antiphase wired second transformer in a 65-0-65 PSU to reduce rippleHide this!Advertise here!
Ill be getting wired here now... phluffy Introductions 2 4th May 2009 03:42 PM
is this wired right? shooto Instruments and Amps 1 17th July 2006 02:47 AM
what size amp for DPL 12 wired for 4 ohm? crippledchicken Subwoofers 7 19th January 2005 11:10 PM
Help:How To Reduce Transformer Output Voltage? phill77 Solid State 0 21st April 2003 12:04 PM
Antiphase wired second transformer in a 65-0-65 PSU to reduce ripple the toasted Parts 1 16th February 2003 06:06 PM
