Old 19th November 2007, 09:59 PM   #1
cocolino's Avatar
Default search for NAD C160 Preamp service manual or schematic
I`d be very grateful if somebody who has the service manual (or maybe only the schematic) for the NAD C-160 could email it to me.
Thank You!
Christoph
STEAL the BEST - INVENT the REST
Old 3rd June 2009, 07:26 PM   #2
alfababy's Avatar
Default Service Manual needed
Hello,
My beloved NAD C160 Pre Amplifier just went dead...
Could any kind soul out there who have the service manual or schematic, please email me a copy.
Will try to revived it.....
Thanks you in advance.
David
Old 3rd June 2009, 08:36 PM   #3
aparatusonitus's Avatar
Default Re: Service Manual needed
That would be me...send me your mail via pm.
Non é mai abbastanza...
Old 11th June 2009, 05:45 PM   #4
alfababy's Avatar
Hello,
Thank you to all those who have offer. I'm really grateful.
I've manage to get the C162 version of the schematic. This should be good enough to troubleshoot the C160.
Cheers.
Old 12th June 2009, 01:08 AM   #5
cocolino's Avatar
Hello again alfababy,
sorry but it seems that You didn`t receive the C-160 service-manual I´ve sent You a few days ago. File size was 22Mb, maybe this was too big? Did You get at least the the other smaller file (3,7MB, modules schematic) I have sent You half an hour later?
Should I try to send You the files again?
Christoph
Old 12th June 2009, 02:06 PM   #6
alfababy's Avatar
Hello Christoph,
I did received the 3.7MB C160 module schematic. Thanks.
It seems that the 22MB is too big to be received by e-mail.
I've compared the C160 module schema against the C162 and it is identical. So i'm currently using the C162 schema for troubleshooting.
BTW, Is there any chance of a blown power transformer if I didn't get any AC voltages from the two 5-pin connectors CZ701 and CZ703?
Cheers.
David
Old 14th June 2009, 04:12 PM   #7
cocolino's Avatar
David,
though not impossible, IMO a blown power transformer is rather rare.
I`d check first if there is any line voltage present at the input of the transformer.
If this is the case there is still the chance that the connectors on the PCB board or the wiring or the connectors on them from the transformer to the PCB are flawed (broken wire, cold or broken solder joint on connectors). A bit of wiggling the transformer secondary wires and connectors might as well show You if and where an error is.
If there is no line voltage at the input of the transformer at all, work from there toward the line input connector while checking for line voltage. Either the power switch, a fuse, wire, a connector or the line input filter is at fault. There are not too many possibilities and it should be quite easy to locate this fault.
Christoph
Old 10th September 2009, 08:17 AM   #8
Hi friends,
i am from germany and i am search for a circuit diagram
for a NAD C 160 or 162.
is it possible that you are help me
my mail adress is: webmaster@alpenluder.de
thanks so much
teddy
Old 27th February 2012, 10:01 PM   #9
Hi there,
I woul be very thankfull if someone could help me with C160 schematic also.
I just got a problem with the remote controlled volume. It stops sometimes and I cannot figure out if theres a faulty stop command coming back from the servo/motor driver section. All other remote controlled functions works ok.
Your help is very much appreciated.
Br. Andy
Old 28th February 2012, 11:40 AM   #10
Default Pre-amp remote giving me a hard time
I did some measurements, but cannot figure it out
I measured +/- appr. 4 volts going to the motor as I push and hold down the up/down vol key on the remote controller, but it just suddently cuts the feed to the motor. Letting go and pressing the up/down key on the remote controller once again, it starts turning the motor again. Sometimes it can do a complete turn, but most often it stops several times during a complete revolution.
I re-soldered as much as I could accoording to the signal path.
I have two remotes that usually workes with the C160, and still works fine on my other NAD amp. (checking the vol up/down).
I've enclosed some screen shots of parts of the schematics, in case someone has a little spare time
Thank you fellow DIY.
Best regards,
Andy
N.E.W. A-20 amp service manual or schematic alaskahiatt Solid State 4 17th May 2011 11:30 PM
Schematic Search - Eden VT-.40 (Valvetech with Demeter Preamp) duff2 Solid State 3 27th August 2008 09:00 AM
In search of power supply schematic for phono preamp jduffy Tubes / Valves 16 9th April 2007 04:58 PM
akai am-52 service manual or schematic bmwdriver325i Solid State 1 1st May 2005 02:20 PM
Page generated in 0.12043 seconds (82.61% PHP - 17.39% MySQL) with 11 queries
