Old 7th December 2007, 12:08 PM   #21
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi Carlos
It's changed a bit since then, as I'm sure many DIY'er projects do. I don't have a good program for electronic drafting, but I think I can show the schematic in sections, since that is the way it operates anyway, to better understand this adventure into a compound circuit. Values would be harder to read so I noted some current flows. It's hard to get the idea without a schematic. So here is another attempt...
The voltage regulator section drives regulated DC to everything except the output transistor drains. This adds up to about 30mA. Output voltage is +/-40V, and +/-15V. It is possible to use a voltage doubler/half wave rectifier from the lower mosfet power source to drive this higher voltage. I did it this way just to see how it works. There is no hum, but of course a full wave rectifier would be better. Not counting the pass transistors, the reg circuits eat up a whole 600uA, and with no Zeners. Those J-fet's are happy at about 100uA. There are 2 matched pairs of J-fets in this stage.
All the trouble I've ever been in started out as fun......
Old 7th December 2007, 12:10 PM   #22
CBS240's Avatar
This circuit is the DC servos and the input follower stage, along with the first gain/phase splitting stage. This circuit has 4 matched pairs of J-fet’s, 3 different types. Ahhh yes, matching fun. The servo circuits are referenced to each output separately. This is DC global feedback, but AC has no global loop. The servo circuit will bias about 3-4 VDC to each input. The DC voltage input for the +in and –in is close but not quite equal to each other, however, it will balance out to 0 VDC on each output across the speaker, and to ground. In fact the offset is never more than about 15 mV in this circuit, but it depends on Vgs matching and equal bias in the servo differentials. Using the balanced bridge as a phase splitter ensures the phase difference of the output signals is always 180 degrees, no matter what the frequency. The -3dB gain frequency points are at 18Hz or so on the low side, and around 500KHz on the high side. Even at 1MHz, the phase does not distort at the output.
Old 7th December 2007, 12:13 PM   #23
CBS240's Avatar
Now on to the VAS. The VAS has a local feedback loop that bias both DC and AC signals at the sources of the input J-fets. This leaves the gates floating, or rather to be driven with a DC and AC source. This is why the phase splitting circuit mismatch in output impedance is negligible, the equivalent input capacitance of these devices is about 5pf or so. Every cascade J-fet CCS in the whole circuit is set to 100uA. This makes the math simpler when figuring resistor values.
CMFB bias is employed in this stage as well as 2 THAT 340 matched arrays as the amplifying transistors in the constant power differentials. There are 3 of these arrays all together, 6 times the cost of all 4 output transistors. Still, I vouch for the THAT arrays, as I stated before, they work well for me.
The Mosfet cascode devices I don’t have yet, I am still using BJT’s, but there should be no problem there, I have used them this way once before in a previous circuit……and the circuit seemed to be a little faster. Fortunately, they have the same footprint as the BJT’s so if they don’t work, the BJT will be a drop in replacement. Can’t see why they wouldn’t.
Old 7th December 2007, 12:15 PM   #24
CBS240's Avatar
Finally to the output stage. This stage should be familiar to anyone who reads this forum regularly. It works quite well. * denotes heat sink mounting. +output and –output are fed back to the servo DC detection inputs. It seems I left the output filter out, but there is an 82 Ohm resistor in series with a small 22nf polypropylene cap on each output to ground. The voltage between points A and B, C and D is about 11V.
I know this seems like a lot of trouble to get 100W RMS, but that happens sometimes when your design goals are high and you deliberately avoid using IC’s and stick to completely discrete. No real reason other than I just wanted to see if/how it could be done. This circuit should be able to use larger/parallel outputs. The operating voltage is limited by the J-fet’s in the VAS stage, but another cascode would fix all that. The capability of this circuit to be expanded is not a bad thing. Fact is, I don’t even need to listen to 100W RMS, let alone 200 or 800W. One would have to have a huge home to listen to a 800W RMS home stereo and not have reverb. Maybe this experience will help get people interested into more “No Global FB” designs. Hmmmm just dreaming, but maybe one day there could be a tracking power supply for the output drains...some day when I learn how to build one. Then again, there was a time when, to me, these results were just a transistor dream.
Ohhhh the clarity of quality audio…it’s beautiful. I can hear more detail from this circuit than any before it. The lack of noise makes classical tunes sound clear and precise. I can even understand all those background lyrics now from the music by Tool. I wish I could get more specific numbers, but I don’t have all the high tech equipment to measure every type of distortion to the N’th degree.
Old 7th December 2007, 12:17 PM   #25
destroyer X's Avatar
Default Man, you are very good...your brain is boiling with nice and hot ideas
Continue to post your ideas...people do not always make comments about our ideas... some of them feel not confortable to write posts, others want to have sure this works fine...others run to test your ideas and goes to the simulator.
We think people is not interested...sometimes we feel no one want to make it.... monthes passes and suddenlu you discover that many folks have constructed and are still listening.
There are folks that do not like to talk, to write, to advertise things, to make noises... or to show happyness.
People has some small differences..some of them are shy..others not.... and this is inside a long rule.... shy at left and not shy at rigth...many levels.
Keep the ball rolling, the machine oiled... showing us your ideas...explain them, i am sure people will read everything...if not too many people...for sure i will be reading your posts.
You know..we learn a lot with other folks solutions, ideas, problems.... this is very helpfull.... every brain storm will feed our souls with nice informs...your problem may be the solution of my doubts and may be your solution too.... keep us informed.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine.
Old 7th December 2007, 12:24 PM   #26
CBS240's Avatar
I hear ya Carlos, you know I haven't run one single simulation on this circuit. It is just an expansion of other circuits I have made and those real circuits worked. This real circuit works pretty good as well but I don't know how it would work in a simulation....or if you could even fit it all in.
EDIT
Here is 1MHz at about 3Vp per side, notice the phase is still perfectly in line with each other.
Old 7th December 2007, 12:28 PM   #27
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Default CBS
Oh Carlos you are too good !!!!
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 7th December 2007, 12:51 PM   #28
Default Man!... this one remembers me a lot..we are not too much different...only in weigth..
I have 180 kg....a heavy weigth "sumo" figther..ahahahah.
Son of a whale....more to white whale than to Orca, the killer whale.
I am not so good.... but really there are folks that i really like a lot...and you are one of them Workhorse.
regards,
Carlos
Very nice wave shape CBS240
regards,
Carlos
Old 9th December 2007, 06:27 AM   #29
CBS240's Avatar
This is a 200KHz square wave, input is about 0.6V and is the top waveform. The postitive output phase is the next waveform, 10Vp per phase, at about 2A RMS. The bottom is both output waveforms. It appears better as X-axis magnification is larger in this faster signal, but both P-channel devices seem a little slow to turn on resulting in some crossover distortion. Right now, each output Mosfet gate resistor is 220 Ohms. Decreasing the gate resistor should speed up turn on, right? The signal on the gate drive is without this crossover notch. The input capacitance of the P-ch is larger than for the N-ch, they are not exactly conplementary so the resistors shouldn't have to be the same, eh? This is why I think that could be the problem. I guess I will have to test it and see.....
Old 9th December 2007, 06:31 AM   #30
CBS240's Avatar
BTW, here is a 60Hz square wave, as the circuit is now, 10Vp per phase at about 2A RMS. Among all this high frequency stuff, you can't forget about the low frequency side either.
Carlos, don't you mean 180lb? You don't have the bloated face of a 396lb man.....unless you are a pro wrestler hopped up on steroids or are 7'1" like the Great Kali......and can pop a basketball or crush a man's skull with your bare hands!
Full Bridge X Half Bridge: What's The Best? CHACALPOWERS Power Supplies 8 18th July 2008 04:45 PM
Reopening an unfinished debate: Dual bridge vs. Single Bridge xiphmont Chip Amps 15 26th February 2008 07:22 PM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 02:10 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
Page generated in 0.13741 seconds (82.44% PHP - 17.56% MySQL) with 11 queries
