Old 16th November 2007, 05:55 AM   #1
Basalt is offline Basalt  Australia
Default Using a headphone amp as a pre-amp?
Anyone here have any experience using a headphone amp as a preamp? Good idea/bad idea? Anything to watch out for (too much gain, impedance matching...??)
Old 16th November 2007, 10:24 AM   #2
SamL is offline SamL  New Zealand
AMB's M3 and B22 headphone amp can be used as preamp as well as small speaker amp. The B22 is very well received and is rated highly as headphone amp. Not sure how it will fatch as preamp.
AMB has a very good build details on his site http://www.amb.org/audio/ and you should find most of the answer there. If not, you can reach him over the headwize forum.
http://headwize.com/ubb/forumdisplay.php?fnum=3
Have fun,
Sam
Old 16th November 2007, 10:44 AM   #3
Gordy is offline Gordy  United Kingdom
Default Re: Using a headphone amp as a pre-amp?
In essence a headphone amp is a preamp with a slightly beefed-up power supply and output stage.
With the vast majority of headphone amps they should work perfectly well as preamps. However two provisos...
1) Some have a silly amount of gain and hence you might not have much usable volume control range.
2) Conventionally wired headphone amps share the output negative connection between left and right channels, and as such the maximum channel separation can sometimes be limited. In reality you may not notice this.
Old 16th November 2007, 12:29 PM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
I'd say 80% of commercial equipment shares ground....
Old 19th November 2007, 10:55 AM   #5
yes, i have built a few pre-amps and the M3 is still the one to beat overall.
Another DAC + Headphone amp ghetto Digital Source 14 10th July 2008 05:02 PM
ESL Headphone X-former bjackson Planars & Exotics 5 19th September 2005 04:45 AM
Headphone amp audioPT Headphone Systems 3 20th September 2004 11:17 PM
Zen v4 headphone amp Rob M Headphone Systems 11 21st May 2003 01:58 AM
sym. Headphone amp Orgonom Headphone Systems 7 15th March 2003 08:28 PM
Page generated in 0.09516 seconds (75.82% PHP - 24.18% MySQL) with 10 queries
