Yamaha CRX-E150, pre-amp section w/ tone controls. What is puzzling me here is, why TWO parallel caps in the feedback loop (C763/C768)?
Wouldn't just one around 50pF (47pF) do as well, or is there some deeper reason I'm not seeing here? And while we're at it, why not even something lower, like 10pF? I mean, with the given values, 1/2*phi*R*C gets kinda odd results for what I thought it should have in this part of the ckt. Then on the other hand, I probably just can't calculate this the right way. |
#2 |
Your calculation is OK: 470k//50pF gives 6.8kHz (-3dB). Strange! Maybe the schematic's value isn't correct about 100pF-100pF. Regards, Donk |
#3 | |
Official Court Jester
they have drekload of 100p caps two in series can have tighter tolerance than just one they teasing us ........ as you see - plenty of solutions ; do not underestimate first one .
my Papa is smarter than your Nelson ! tnx to |
#4 | ||
![]() Quote:
![]() How about phase, nothing to do with that on this part? |
#5 |
Are they really parallel?
Or both used for a 2nd order response? Is there a resistor lurking near by?
Just because you can't hear it doesn't mean no one can. |
#6 | |
Filtering they sure are, like the whole section there, being part of the tone controls. But how much should they filter out? I would've placed the cutoff point somewhere above 20kHz, which would mean way smaller values for those caps. But those C756 and R755 throw me off on my calc. I see a band pass here also, but should I? Suggestions for calculations and all gladly taken, thanks for the replies so far people. |
#7 |
Look at the whole circuit: the 470K resistor is also in parallel with the network of VR701, R704, R705, and VR702, which off the top of my head (too much work to calculate this properly) looks like about a few K in series with R759, so the effective resistance at signal is not far from 10K because the impedance of C760 is negligeable at signal frequencies.
#8 |
Sorry,
The viewing mode I use doesn't show attached schematics. ![]() I was going by the post text. But, as to your question, yes one 50PF would work. Also, The network is in parallel with the EQ
#9 | ||
It seemed simplest just to bypass the whole tone ckt, rather than try to figure out something "neutral" or such. Then again, can't really carve the front panel of this box for any kind of extra control, there's a big PCB right against it (like there are all over this tiny box). So now I'm back to thinking how at least to try and make the best out of what is already there. Quote:
Looking back...I didn't mean my remark about the schematics to be snotty, but just to clarify that it's been checked to be right. I've read way too many schematics myself which proved not to be that accurate when checked against the real things. Apart from possible copyright issues(?), drawing these myself, I can also at least try to make them as simple and clear as possible. Thanks for the replies. Any insights welcome, as always. |
| Any disadvantage to multiple parallel caps for PS? | theAnonymous1 | Power Supplies | 14 | 31st May 2009 05:09 PM |
| Active Feedback on Parallel Chips | Stocker | Chip Amps | 8 | 4th May 2004 10:40 PM |
| lots of parallel caps, why? | JojoD818 | Solid State | 25 | 14th January 2004 07:39 AM |
| Are Parallel smaller caps better/worse than big? | Arx | Parts | 4 | 9th November 2003 11:54 PM |
| PS caps in parallel | Bill Fitzpatrick | Solid State | 6 | 14th October 2002 10:56 AM |
| Page generated in 0.12485 seconds (76.89% PHP - 23.11% MySQL) with 11 queries |
