#611 | |
#612 |
Is the 1W requirement for this part correct in your BOM?
#613 |
It is correct. My diode is in a little large package, i think is DO-41 (2mm diameter) glass, but DO-35 500mV will suffice.
In fact, is not important how large this diode is, if it fit between TO-129 cascode devices |
#614 |
Great. That makes things easier. I was wondering why you specified a 1W part to carry only 1ma.
#615 |
I was thinking a mechanical switch on the heatsink to trigger a latching relay to cut off power.
But using the diode as a fast warning that overheating is starting to occur,
regards Andrew T. |
#616 |
Again. What about the wattage of the 36v zener in the front end power supply? Anything I find availabe in 1W comes in a DO41 package with .8mm dia leads that won't fit in the holes on the circuit board.
#617 | |
Or perhaps, in addition, use the signal to shunt the bias pot. |
#618 | |
If you do the math you'll see that at Vr 1mA that diode will dissipate 36mW, so 500mW glass case will be more than enough |
#619 |
About a year and a half ago there was a thread about thermal pads for TO264 packages like the ThermalTraks, and how no one new a source for any. It looks like after another year and a half, not much has changed.
I did find a mica one from Aavid that would appear to work, but I can't find any suppliers for small quantities. It is model number Aavid Mica Insulator #56-02-101 If anyone can find a source for it, a group buy may be in order. Any other suggestions? |
#620 |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| lucylu |
| Single stage amplifier | Skorpio | Pass Labs | 33 | 5th January 2011 02:03 AM |
| RMI-FC100 MKII, single ended folded cascode VAS | roender | Solid State | 27 | 9th July 2010 10:56 PM |
| single stage common-drain amplifier | Music_Sg | Solid State | 4 | 4th July 2006 05:45 PM |
| Page generated in 0.11717 seconds (75.49% PHP - 24.51% MySQL) with 11 queries |
