Old 9th January 2009, 01:31 PM   #601
atiq19 is offline atiq19  United Kingdom
Is it worthwhile adding some kind of mods like technics ouput scheme to make output transistors free from switching?
Just curious..
Atiq
Old 9th January 2009, 06:55 PM   #602
pooge is offline pooge  United States
Mihai,
I am curious about how you arived at the particular component values for your Zobel network. Not critizing, because I am not an expert here.
I ask because in Self's treatment of the matter he indicated that the resistor is usually selected to be about the same as the speaker load, with the capacitor at 100nf, and concluded that it simply worked that way. Although he tried different resistor values to no gain, he didn't mention any experiments to change the 100nf cap.
Old 9th January 2009, 07:09 PM   #603
roender is offline roender  Romania
roender's Avatar
I have 6ohm speakers, so two paralel 10ohm resistors are close to Self recommandation
Old 9th January 2009, 08:40 PM   #604
Sorry. I got the resistor value part. I was wondering about the cap, but realize now it is just scaled up for the lower resistor.
Old 10th January 2009, 05:04 AM   #605
Mihai,
What kind of package is D1 1n4148? Can't see it between the transistors in your photos. Is it a DO-35 package? I ask because I assume the diode is stood up with the leads bent over at the top, and I see that the resistor in series with it has an insulated lead, yet there is no reason the resistor and diode can't touch, since they are connected together anyway.
Old 10th January 2009, 11:19 AM   #606
Could we use the spare diode in the output to feed a comparator and give an overheat indication? Maybe a flashing LED?
Thoughts please.
Old 10th January 2009, 02:08 PM   #607
roender's Avatar
Thoughts please.
Yes Andrew, good idea.
I was thinking to cut the power when heat sink temperature is over 85C
Old 10th January 2009, 02:11 PM   #608
roender's Avatar
Originally posted by pooge
Mihai,
The 1N4148 diode has 1W glass package. I don't know the code name of the capsule...
The diode leg is isolated in order to not dissipate heat into cascode voltage reference 10Kohm resitor.
We want that diode to closely track the thermal variance of the cascode devices.
Old 10th January 2009, 03:32 PM   #609
I was thinking the same thing. Of course, with the present board layout, those leads would be hard to access if the transistor leads are not soldered the board, unless some traces are cut and jumpered elsewhere. Perhaps in MK1.2a boards. ^\^
Old 10th January 2009, 03:37 PM   #610
Is it one like this, stood up with the top lead bent over?
DO35 diode
So should both the diode lead and the resistor lead be insulated?
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 27 9th July 2010 10:56 PM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
Copyright ©1999-2013 diyAudio
