RMI-FC100, a single stage audio power amplifier
Old 27th December 2008, 12:52 PM   #501
m2003br is offline m2003br  Brazil
and this:
Old 27th December 2008, 12:53 PM   #502
roender is offline roender  Romania
roender's Avatar
Originally posted by pooge
What is the maximum voltage drop the PSU regulator can do, so we can know the voltage range for acceptable transformers. Also, what is the minimum and maximum difference acceptable between the PS voltage delivered to the input stage and that to the output stage?
At least 5 volts between input and output
The front end PSU must deliver 5...8 volts over the output stage PSU in order to cover headroom lost by folded cascode bias voltages
Best regards,
Mihai
Old 27th December 2008, 12:58 PM   #503
pooge is offline pooge  United States
Originally posted by roender
It is better now?
Much. Thanks.
Old 27th December 2008, 01:04 PM   #504
I think I achieved a better one for the amp board.
Happy new year for all!
Old 27th December 2008, 01:05 PM   #505
Default Re: layouts
Originally posted by m2003br
Hope this may help:
The labelling would be much more readable if you dropped the circuit pattern and left just the vias. Also, there was a tweak for C1 with the addition of a series resistor.
Old 27th December 2008, 01:23 PM   #506
Hello Pooge,
Better now?
Old 27th December 2008, 01:50 PM   #507
Mihai,
What you think about the use of a better and bigger resistor in the NFB (R24 - 22K)?
Thank you,
Marcos
Old 27th December 2008, 01:57 PM   #508
Best regards,
Mihai
Are you talking about the regulator board here? If so, what is the maximum allowable input voltage?
Old 27th December 2008, 02:09 PM   #509
roender's Avatar
Yes.
The max input voltage? Don't know, never think about ... depends on how big the PSU heat sink is and SOA of the used CCS transistor.
With specified parts and 39V output voltage I wouldn't go over 55V input voltage
Old 27th December 2008, 02:19 PM   #510
roender's Avatar
Mihai,
Thank you,
Marcos
If you think that using a bigger wattage resistor is better for the sound, go ahead, no problemo! I believe that there is some space on PCB for 1w RPM resistor but no more than that
RMI-FC100, a single stage audio power amplifierHide this!Advertise here!
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 29 29th March 2017 07:44 PM
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
Copyright ©1999-2017 diyAudio
