Old 1st December 2008, 02:28 AM   #481
DRZ1 is offline DRZ1  Canada
Originally posted by roender
Denis,
I think you have some ground wiring problem, or more than 92bB SPL speakers.
Where did you put the speaker return wire? Into the star ground, in the middle of the board?
Yes it's connected to the star ground. I suspect the small transformers i have used for the drive supply, but i'm not shure.
I have made some tests (distance it ) and i have found the front end pair very sensitive to electro-magnetic fields.
Maybe my ground plane PCB (not grounded in fact ) ????
If you have some other idea.
Old 3rd December 2008, 01:34 AM   #482
MJL21193's Avatar
Originally posted by MJL21193
Here's the first working model of my version with bjt input:
No comments on my escapades? Oh well.
I put it on a heatsink and did a full power test - looks very good. I have configured it to run on +/-72V rails, but input sensitivity limited to 150 watts output. This ensures plenty of headroom to avoid clipping.I worked out some of the bugs and finalized my layout:
All of the outputs plus the CFP drivers are mounted under the board in contact with the heatsink.
Thanks roender for the great design.
Old 13th December 2008, 07:06 PM   #483
Send a message via MSN to robson fulco
Default PLACA
HELLO GOOD AFTERNOON!!
HOW FASO TO ACHIEVING A CARD THAT YOUR AMP. Was reading out about ELE And I love OK ....
Old 20th December 2008, 07:50 AM   #484
housing is offline housing  Hong Kong
Hi Mihai,
How did you match the transistors? Thanks!
Old 20th December 2008, 08:31 AM   #485
roender is offline roender  Romania
roender's Avatar
Originally posted by housing
Hi Mihai,
Which transistors?
Old 20th December 2008, 08:53 AM   #486
Q19-Q20
Q1-Q3
Thanks.
Old 20th December 2008, 09:13 AM   #487
roender's Avatar
Use a DMM to measure hfe.
Old 26th December 2008, 01:44 PM   #488
pooge is offline pooge  United States
Any opinion on which of these transformers would be best for the output stage for a single channel? The Antek is a lot cheaper and heavier, but I read an opinion somewhere, without explanation, that the Avel was better quality. Is anyone familiar which any quality difference between these lines of transformers?
Avel Transformer
Antek Transformer
Has anyone found a USA supplier for a standard off-the-shelf transformer for the input stage?
Old 26th December 2008, 02:27 PM   #489
jcarr is offline jcarr  United States
Mihai, just wanted to offer my congratulations on a clean, capable design that shows that you have put a lot of thought and time into it. It is a pleasure to look over your work. Nice!
In fact, it looks like something that I would design (^o^).
Happy holidays! jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 26th December 2008, 03:36 PM   #490
roender's Avatar
Mr. Jonathan Carr,
Thank you very much for your kind words.
I must confess that I am a big fan of yours and I'm glad that we have you back on diyaudio ... I hope.
This design is very much yours. I was guided by many posts you had writhed on the net.
I would like to ask you a question, if I may?
I've been thinking to version two of RMI-FC100 for a while. I want to use Li Ion rechargeable battery as front end power supply and I don't know if i could replace LTP CCS with a simple resistor and also all folded cascode CCSs with JFETs configurated as CCS at zero TC, in order to allow an exceptional HF behavior.
I would like to make this design as simple as possible from singal path point of view.
What do you think about?
Best regards and
Happy Holidays,
Mihai Rauta
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 27 9th July 2010 10:56 PM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
