Old 12th November 2007, 08:15 AM   #21
roender is offline roender  Romania
roender's Avatar
Originally posted by Zen Mod
roender
D1 is there because of tempco?
also 2SC3423 .......... there are here because of noise and temp. behavior ?
tnx.
D1 is there for tempco. It is thermally coupled with input stage cascode devices.
c3423/a1360 are used becose they have a very low Cob. IMHO those are the best VAS transistors, even if I don't have a truly VAS here
Old 12th November 2007, 08:18 AM   #22
roender's Avatar
Originally posted by Duo
Why do you call this a single stage amplifier?
"VAS" has a common base topology
Old 12th November 2007, 08:39 AM   #23
destroyer X's Avatar
Default Class A sounds beautifull..... but not possible to my environment
Under normal weather conditions is already hard to face the temperature here.
Without heaters, as Television, Owen and equipments in stand by is supportable....but with a class A powered on, here, is a suicide.
Nice design, pretty construction, congratulations.
Made from an European and to the Europe....and only during the winter.
Correct...no one use more than 2 watts.... so... the normal AB amplifiers will operate into class A till 2 watts and will be reasonable....but, for sure pure class A is another thing...better!
It is lovely and interesting how people is different....Nelson Pass and also me will feel very unconfortable using so many parts when 1 or 2 will produce the same power.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!.. when not work first time, then becomes a nice challenge...and we usually overcome the trouble... and we feel very well to be mastering the machine.
Old 12th November 2007, 09:03 AM   #24
roender's Avatar
Default Re: Class A sounds beautifull..... but not possible to my environment
regards,
Carlos
Thank you very much Carlos.
The question is, at the same output power an amp with few parts will sound better or worse than one with a lot more components?
I have made a lot of amplifiers and I've come to this conclusion:
One can use components "outside" signal path, to make an amplifier response more linear, without hurting how that amp will sound.
Regarding A classe, the power dissipated at idle is 35W per channel. With 0.37W/C heatsink, the radiated temperature will not be unsupported.
Old 12th November 2007, 09:12 AM   #25
Default Yes...you are rigth....those surrounding sub circuits helps a lot
For sure you are rigth.... will sound better.
regards,
Carlos
Old 12th November 2007, 09:19 AM   #26
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Okay, so I suppose that the input pair is operating into the common base amp which is a sort of cascode driving the output stage. But would this still not be a two stage amplifier at the very least?
Old 12th November 2007, 09:27 AM   #27
roender's Avatar
No
The LTP is not in common base topology , it is the only stage which amplifies signal.
The output stage is a unity gain stage. It's an impedance adapter, emiter follower ...
Old 12th November 2007, 09:29 AM   #28
Duo's Avatar
I see that the LTP is not in common base, it is common emitter with jfet drivers.
But it appears as if it drives a common base stage before the output stage.
EDIT: I meant common source jfet; no drivers. I'm pretty tired right now. I should sleep.
Old 12th November 2007, 09:31 AM   #29
roender's Avatar
What gain is in that stage?
1!
Old 12th November 2007, 09:32 AM   #30
Duo's Avatar
I never said the gain wasn't 1. But it is still considered a stage.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
lucylu
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 27 9th July 2010 10:56 PM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
Page generated in 0.11030 seconds (78.62% PHP - 21.38% MySQL) with 11 queries
