RMI-FC100, a single stage audio power amplifier
Old 26th January 2008, 07:00 PM   #241
Bob03 is offline Bob03  Canada
Bob03's Avatar
Cool Yes it is
Old 26th January 2008, 09:47 PM   #242
tryonziess is offline tryonziess  United States
Roender, The original schematic at the beginning of the post only shows 5 of the thermal trac diodes connected in the diode string. Where is the sixth thermal trac diode connected? Tad
Old 27th January 2008, 05:59 AM   #243
roender is offline roender  Romania
roender's Avatar
It is routed in the PCB but in short circuit. See pictures below.
Old 28th January 2008, 07:13 PM   #244
niner is offline niner
Roender, what's the spec for D7 and D8 in your front end power supply?
What is the dimension of the heat sink? do you think it is the right size? or you would go bigger/smaller?
Old 28th January 2008, 07:50 PM   #245
R.I.P.
only just found and couldn't stop reading this thread.
Roender,
Superb.
Could the quality of sound be, in part, due to the very few capacitors in this design, nine in all? There are twice as many transistors (18) excluding the 6output devices and almost all of these are high fT and high hFE.
regards Andrew T.
Old 28th January 2008, 09:23 PM   #246
roender's Avatar
http://www.diyaudio.com/forums/showt...22#post1354022
The heatsink has 0.37C/W (300x150x25mm).
Old 28th January 2008, 09:25 PM   #247
roender's Avatar
Originally posted by AndrewT
Could the quality of sound be, in part, due to the very few capacitors in this design, nine in all? .
Thank you Andrew.
Old 28th January 2008, 09:25 PM   #248
Thanks Roender, I saw that, but I'm not familiar with Z39. Is it a 39v zener?
Old 28th January 2008, 09:41 PM   #249
roender's Avatar
Hi niner,
I make a little mistake in the frontend PSU BOM, it is a 36V zener diode, not 39V.
Thanks,
Mihai
Old 28th January 2008, 09:51 PM   #250
Thanks Mihai.
I have most of parts in my procession. Only things I need is PCBs and transformers. Hopefully I can start the build in a week.
RMI-FC100, a single stage audio power amplifierHide this!Advertise here!
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 29 29th March 2017 07:44 PM
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
