Old 30th November 2007, 02:42 PM   #131
DRZ1 is offline DRZ1  Canada
Originally posted by roender
Hi DRZ1,
I don't know what is this "milling prototype machine" and what type of files can be use to make boards.
I can send to you all CAD files if you want to make some changes but I must warn you that you will need a valid EAGLE license because the PCB dimensions is over maximum permissible free version size.
Mihai
It's a milling machine specialised for milling PCB board. It's used for testing PCB design before production. Works with gerber files. I use Protel soft.
http://www.mitspcb.com/
Denis
Old 30th November 2007, 04:24 PM   #132
aparatusonitus's Avatar
Originally posted by lumanauw
You can try this correction system by putting C from output node (before L) to emitor of Q14. Initial approximation value could be 30pf (C8//C9), but it must be adjusted in the real amp.
(in aparatusonitus' amp, put another 47p//165k from output to emitor of Q11a)
Hi lumanauw,
A and B nodes are input and output nodes of current mirror, so in my sch C3//R34 have to be connected to collector of Q11A, not emiter, see sch below.
Non é mai abbastanza...
Old 30th November 2007, 07:53 PM   #133
roender is offline roender  Romania
roender's Avatar
Hi, Roender, aparatusonitus,
... looking at your schematics, it is quite easy to experiment with it.
If you look at this attachment, the correction system is possible because there is a "virtual" inverting input of the output stage, that is point A.
The correction works optimal if impedance of "32a" (that is element 56+54) is the same (calculate the gain first) to the impedance of "36a" (that is element 62+60).
In your schematic, element "32a" is C8//C9.
(In aparatusonitus' is C12//R38)
David,
The distortion cancelation method, a la Wurcer's ad797, is applicable only if you have the same impedance, as high as possible, into the input and the output of the current mirror. In my design there is no floating current mirror and the input has low impedance compared with the output.
I am not sure if it is possible to implement AD797 topology in a discrete power amplifier.
Mihai
Old 30th November 2007, 08:11 PM   #134
I am not sure if it is possible to implement AD797 topology in a discrete power amplifier.Mihai
Hi Mihai,
Before I went this road in design, I have ask the man himself, Scott Wurcer, whether is it possible to design AD797 style discrete preamp/opamp…guess you know the answer.
Old 30th November 2007, 08:21 PM   #135
roender's Avatar
Originally posted by aparatusonitus
Hi Mihai,
It is pointless ... because for a discrete preamplifier you can use an class A output stage, well ... it is highly recommendable to do that!
The cancelation method described in US patent 5166637 is applicable only if you want to avoid high power dissipation in output stage.
Old 30th November 2007, 09:32 PM   #136
forr is offline forr  France
forr's Avatar
Hi Aparatusonitus,
I think you use Baxandall's constant current sources.
No high frequencies problem with them ?
What's the purpose of the CCS around Q5 and Q6 ?
Old 30th November 2007, 11:15 PM   #137
I have tried to sim my sch with and without cancellation network, and IIRC got something like 25dB less H2 with cancellation network (not that I’m a THD freak). Try to look at it as a first experiment if I ever decide to build a power amp upon it.
I have not notice any HF problems in sim (mind you I’m not an EE and will never be, I have just keep notes from the gurus here ), but as usual I have to build the real thing first to see wether it oscilates or not.
Wrong copy/paste move, just neglect all schebang around them.
Old 1st December 2007, 01:57 AM   #138
diyAudio Moderator Emeritus
Hi, aparatusonitus
Sorry I don't look at your schematic further, you've already implemented the patent
In the schematic in post #132, what is the function of Q12? What does it do in your SIM?
Old 1st December 2007, 08:01 AM   #139
roender's Avatar
David,
Q12 make current mirror point C to swing with output voltage level. In this way, the input of CM, point A, has the same impedance as the output, point B.
Guys, please open a new thread dedicated for this ad797 topology.
Thank you
Mihai
Old 1st December 2007, 09:40 AM   #140
OK, lets continue with Roender amp.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
lucylu
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 27 9th July 2010 10:56 PM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
Page generated in 0.13617 seconds (76.36% PHP - 23.64% MySQL) with 11 queries
