RMI-FC100, a single stage audio power amplifier
Old 31st July 2013, 09:08 PM   #1271
atupi is offline atupi  Romania
I think you can order thermaltracks from Mouser or from Onsemi using their sample program in september.
Sk170br you can fing on ebay from reliable vendors.
Contact Rudi, he will give you some nice tips.
Old 31st July 2013, 10:47 PM   #1272
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Originally Posted by hahfran View Post
I happened to read this thread only yesterday. This design seems perfect to drive fast rising broadband speakers. But alas component woes by the number. Thermal track BJTs unavailable and the sK170 only with the GR spec. If I could get some thermal tracks via ebay , could I get along with just 1 pair in the power stage? ( Then a Vbe multiplier is necessary of course)
I can sell you mine if you want,very likly I shall never build my FC100
Old 10th July 2014, 06:42 AM   #1273
nzw709394nzw is offline nzw709394nzw
Simply beautiful.
Old 10th July 2014, 08:56 AM   #1274
Mine is sold in the mean time
Old 7th August 2014, 01:52 PM   #1275
UltimateX86 is offline UltimateX86  France
HI
Do you have the last LTSPICE file ?
Old 30th October 2014, 12:27 AM   #1276
marcus1 is offline marcus1
Default C8, C9
Is it possible to increase the value of either C8 or C9 (both 15pf silver mica caps) on the main board?
The reason I ask is that I mistakenly ordered one 15pf and one 18pf instead of two 15pf. Would using these two be detrimental to the cct design or should it be OK?
If OK, which one should be 18pf; C8 or C9?
Old 30th October 2014, 07:53 AM   #1277
roender is offline roender  Romania
roender's Avatar
The difference is to small to cont. Don't worry ;-)
Old 30th October 2014, 06:54 PM   #1278
OK, thanks
Old 25th March 2015, 04:55 PM   #1279
rotundu is offline rotundu  Moldova
Default Transistor Matching
Hi Mihai! I am in the process of constructing your amp FC100 and do not quite understand hoe to match output devices - NPN-PNP by hfe - i.e. NPN-PNP - 1 = hfe 1; NPN-PNP - 2 = hfe 2 etc., and the same with vbe? Or, all the devices must have the same vbe and hfe? Please explain. Thank you.
U$1 Q2 NJL0281D Must have the same Vbe +-1mV with the same NPN or PNP with matched hfe
U$2 Q12 NJL0281D Must have the same Vbe +-1mV with the same NPN or PNP with matched hfe
U$3 Q25 NJL0281D Must have the same Vbe +-1mV with the same NPN or PNP with matched hfe
U$5 Q4 NJL0302D Must have the same Vbe +-1mV with the same NPN or PNP with matched hfe
U$6 Q5 NJL0302D Must have the same Vbe +-1mV with the same NPN or PNP with matched hfe
U$7 Q27 NJL0302D Must have the same Vbe +-1mV with the same NPN or PNP with matched hfe
Old 25th March 2015, 06:28 PM   #1280
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
YMMV, but in general you will not find both the NPN and PNP with the same Vbe at similar operating conditions - in the case of the NJL/NJW pair above, they will defer by 10s of mV. Also, you will generally find the PNP beta to be higher than the NPN beta at similar operating conditions.
RMI-FC100, a single stage audio power amplifierHide this!Advertise here!
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 29 29th March 2017 07:44 PM
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
Copyright ©1999-2017 diyAudio
