Old 11th January 2012, 10:32 AM   #1211
zdr is offline zdr  Belgium
zdr's Avatar
I am just enjoying the build - I would not count on myself as an amp reviewer (unless there is really dramatic change in sound)
Old 17th January 2012, 09:59 PM   #1212
zdr's Avatar
Well, I am done now. I just have one little problem - how do I stop those little hairs on the back of my neck from standing up while this baby is playing?
I am done with amps now, I might build one day another just like this one. I just need to solve some minor hum issues, and it's getting a bit hot with Re=0.1 on those small sinks, so I might go for 0.22.
I am using BF862 in the front. Right channel pair is matched on Idss only at 0.01mA, and offset is at 0.4mV. The other channel is a bit loose at 1.4mV.
Old 17th January 2012, 10:21 PM   #1213
zdr's Avatar
Photo:
Old 21st January 2012, 09:32 PM   #1214
zdr's Avatar
I had a strange occurence today. I had to increase all Res to 0.15ohm since my sinks were not up to the task. When I reassembled the amp, I got trafo hum from both channels - and excessive buzzing noise from the output stage toroid itself. I disconnected output stages of both channels and noise went away. I connected one channel back, still no noise. I put back the second channel - again no noise! Any ideas what happened?
Old 23rd January 2012, 07:54 AM   #1215
Macleod is offline Macleod  France
And what happen is you plug in first the faulty amplifier?
Is the DC level at the output of the amplifier 0V?
Toroid may buzz when a DC current flew through their windings. Depending on the way you designed the power supply (one diode bridge or two diode bridges?), different consumption on + and - rail main lead to DC current.
Check DC condition with no signal and compare Left and right channels.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
lucylu
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 27 9th July 2010 10:56 PM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
Page generated in 0.10056 seconds (74.39% PHP - 25.61% MySQL) with 11 queries
