RMI-FC100, a single stage audio power amplifier
Old 7th December 2011, 05:46 PM   #1141
Rudi_Ratlos is offline Rudi_Ratlos  Germany
Rudi_Ratlos's Avatar
Dear all,
I just opened a group-buy thread for this beautiful AMP:
http://www.diyaudio.com/forums/group...ml#post2810587
You can show your interest in PCBs there.
Best regards - Rudi_Ratlos
Old 8th December 2011, 01:58 PM   #1142
AndriyOL is offline AndriyOL  Ukraine
I have a little bunch of spare matched Toshiba TTC5200/TTA1943, 2SC3423/2SA1360, Onsemi BC550 transistors for this amp. Will sell them to anyone interested after a while.
If for pristine and pure adoration - it's diyAudio dedication!
Old 14th December 2011, 09:17 PM   #1143
zdr is offline zdr  Belgium
zdr's Avatar
I am still a bit puzzled about matching output transistors.
I have a bunch of NJL0281 and NJL0302. When I try to initially just select them roughly by Hfe with DMM, I find out that PNPs are in the range of 66-95, and NPNs from 120-140. How do I even begin with results like this? Should I ignore this and go to the next step, assuming that my chinese dmm is off?
Mihai mentioned that he matches them with 100ma Ic and 20V Vce, by Vbe and Hfe. How about the rest of the parameters? Is Ic fixed with current source? How's base connected? Some more details would be highly appreciated, since I don't have a PS with current limiter and would have to build something from scratch with LM317.
Old 14th December 2011, 09:26 PM   #1144
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
matching is needed between N mates , and between P mates
you can't match N with P , at least not without significant number of transistors on disposal
in any case - you can't match them with Hfe test on DMM
for matching jig - I don't have handy schm for that
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 14th December 2011, 09:27 PM   #1145
use 12V battery as psu, preferably from a car. Testing jig schematic has to be designed to limit collector current
Old 14th December 2011, 10:21 PM   #1146
zdr's Avatar
Hah, someone please unconfuse me. What is this table showing then:
"The matching was made at 100mA Ic and 20V Vce. The following transistors was selected from a lot of 15 peers
NJL0281 [npn] NJL0302 [pnp]
hfe Vbe[mV] hfe Vbe[mV]
138 593 133 600
136 592 133 600
134 592 133 600
132 594 129 600
128 594 129 600
129 594 128 600"
Old 15th December 2011, 10:46 AM   #1147
R.I.P.
the column headers are hFE (the DC current gain), Vbe ( the voltage between base and emitter when the transistor is passing current), hFE, Vbe
The numerals are slightly displaced from the headers but I can clearly see which column of data belongs under which header.
Now to the data
138 = the hFE when the transistor is tested at that Ta and that Tc which existed during the testing (both are probably changing as the test progresses.
593 = mVbe when the transistor is passing the test current specified earlier (100mA) when the Vce = 20Vce. These first two figures are for the NPN of the pair.
133 and 600 are the respective figures for the PNP of the pair.
regards Andrew T.
Old 15th December 2011, 11:49 AM   #1148
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by zdr View Post
unconfuse
Did you also read the last line ?
Those values were measured with the output devices mounted, aka connected to the emitter resistors !
For close hFe numbers of PNP/NPN, you'd need MJW0302-MJW0281, factory matched within 10%.
Unfortunately for you, Onsemi cancelled their production within two years after their first release. (one reason why folks as me monitor various audio fora)
10% matched NJW1302/3281 are still in active production, can be ordered at DK etc, 0302/0281 can be get at OnSemi's NOS outlet.
Neither the 0302/0281 and 1302/3281 are ThermalTraks though.
To obtain close matching hFe numbers for complementaries, you're stuck with the classic way : order a motherload of them.
(old fart trick to get close-matching Japanese devices was using a higher grade PNP than the NPN, e.g. O+Y grade or Y+P)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 15th December 2011, 01:59 PM   #1149
zdr's Avatar
My point is this - posters above said:
"you can't match N with P , at least not without significant number of transistors on disposal"
Then I see this:
138 593 133 600
136 592 133 600
134 592 133 600"
Looks like Mihai not only matched P with N, but also from a lot of 15 peers. Unless peers means "loads of them", I am still
Old 15th December 2011, 02:18 PM   #1150
History time :
Mihai Rauta ordered a MJW sample kit from OnSemi, somewhere in '06, those are factory matched within 10%.
Then he got the Thermaltraks from OnSemi, the 15 complementary pairs he mentioned, could be those were early production samples too.(with closer hFe numbers)
You measured them with a DMM, which is pretty meaningless.
DMM measuring of hFe somewhat works for little critters, TO-92 and the likes, not for power devices.
Afair, hFe of the Thermaltraks is 75 minimum, so the 66 you measured should already have told you that the DMM routine is not OK.
A TO-264 you have to mount to a heatsink, with a Ic in the order of 100mA and up going through it.
To make it even more realistic/accurate you'd have to mount all of them to the same heatsink simultaneously, wait for thermal equilibrium, then measure.
Even when you measure their hFe properly at 100mA Ic, that Mihai managed to obtain 6 pairs within 8% (138/128 is ~1.078) from 15 pairs total doesn't imply that you will. (production hFe spread can vary from 0 to 100%)
RMI-FC100, a single stage audio power amplifierHide this!Advertise here!
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 29 29th March 2017 07:44 PM
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
