RMI-FC100, a single stage audio power amplifier - Page 111 - diyAudio
Old 15th April 2011, 06:31 PM   #1101
Originally Posted by Sheldon View Post
Look up the symasym schematic. Replace the FC-100 diode string and pot with the symasym's BD135 (or similar) and the resistive divider to its base.
SymAsym5 - Project
Thanks for reply.
Isn't it possible just to replace the diode string with NPN only base to emitter junctions and make it like this: RMI-FC100 MKII, single ended folded cascode VAS regarding pot?
Alas BD135, BD139 have TO225 Style1 package (emitter-collector-base). I think better will fit TO225 Style3 (base-collector-emitter), but I only found MJE13003. Do they need to be thermally matched?
If for pristine and pure adoration - it's diyAudio dedication!
Old 15th April 2011, 09:07 PM   #1102
Sheldon is offline Sheldon  United States
Originally Posted by AndriyOL View Post
Thanks for reply.
You could use most any diode, if you want to do it that way. Ideally, they will match the temco of the thermaltrak diode. Perfect match is not strictly necessary, but should be reasonably close. You could use the holes in the PCB for that purpose, but I don't see how you are going to get them fastened to the heat sink. Easier to mount them on top of the output devices, and just run wires to the transistor/diode terminals, in which case it doesn't matter what the pin orientation is.
There is no pot in the link you show. But I assume that the bias was set with a pot, the value determined, and a resistor substituted for the pot. You can do that with the standard version if you like, and if you don't intend to change the bias point.
Sheldon
Old 16th April 2011, 04:13 AM   #1103
ostripper's Avatar
= MUR120 (ON) diode.
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 17th April 2011, 10:20 AM   #1104
I've remade a layout to fit TO225 Style 3 on the heatsink. But if it's not necessary, can I use mur120 or any other equivalent diode is the spare holes of the PCB without fastening them? Are you refer that I can change the pin orientation by wires or it doesn't matter what the diode string orientation is in the schematic?
Regards.
Old 17th April 2011, 02:18 PM   #1105
Regards.
I was assuming that you are using Mihai's layout, which would make it mechanically difficult to solder transistors or diodes to the board and also attach them to the heatsink. But if you have to change the layout to account for the pinouts of the new output devices, then it should be possible to make the necessary changes to accommodate a diode.
The diode electronic orientation, of course, matters. It must be as shown on the schematic. But if you are not soldering the diode directly onto the board, and instead connect them with wires, then the mechanical orientation is flexible and you can use any suitable form of diode. If you are redoing the layout, then I would suggest that you arrange it so that the diodes sit directly on top of the output devices (except for one, as you need only 5 diodes).
Sheldon
Old 17th April 2011, 04:55 PM   #1106
See here: Based on Hugh Dean's AKSA 55
Old 17th April 2011, 05:24 PM   #1107
roender is offline roender  Romania
roender's Avatar
Hi guys!
There is no reason to use an external diode string for the Vbe thermal compensation. It is complicated to mount and there is no advantage from thermal tracking point of view. Instead, use a classical transistor based Vbe multiplier mounted on top of one of the power transistors, like in the AKSA design.
How is life now, here in DIY community?
Mihai
Old 17th April 2011, 07:43 PM   #1108
That's what I did. I made the layout to attach diodes to the heatsink.
What is preferable, attach diodes to the heatsink or place them on top of the output devices?
Hi Mihai. As you see this thread of RMI-FC100 amp cannot sustain without it's designer.
No advantage even if I can attach diodes (base to emitter junctions) to the heatsink (I made it as MKII layout)?
Vbe multiplier might work hot.
Regards.
Old 18th April 2011, 01:26 AM   #1109
AAK is offline AAK  United States
Like this?
Love when you can, Cry when you have to, be who you must, that's part of the plan.
Old 18th April 2011, 04:37 AM   #1110
The advantage of the Thermaltrak devices, is that the diode is on the same die as the transistor. Therefore it closely tracks the transistor temperature. The further away it is, the more it lags behind the transistor temperature. So if it can't be on the same die, then mounting it (or a Vbe multiplier) on the output transistor is next best.
Isn't that exactly what the designer just said, or is there some misunderstanding?
Why would it work hot? It's not dissipating any significant power. It's simply working against temperature related bias change.
Sheldon
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 29 29th March 2017 07:44 PM
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
Copyright 1999-2017 diyAudio
