RMI-FC100, a single stage audio power amplifier - Page 101 - diyAudio
Old 22nd September 2010, 05:48 AM   #1001
housing is offline housing  Hong Kong
Originally Posted by Sheldon View Post
Just there to thermally couple the transistors and the diode. It's a refinement more than a necessity, as they are touching anyway. The thermal time constants are fairly large compared to music signals, so they just keep bias drift lower. You can use heatshrink tubing there, as the total dissipation is low.
Sheldon
Thanks, Sheldon. I'll stick to the heatshrink tube there.
Old 24th September 2010, 09:41 AM   #1002
pooge is offline pooge  United States
Roender,
This post advocates using red LEDs instead of green ones. If what this post says is true, could you suggest modifications to your amp to accommodate a change from green to red? Thanks.
OpenLoop Gain and compensation
Old 24th September 2010, 10:14 AM   #1003
wahab is offline wahab  Algeria
Somewhat marketing like annoucements...
This amp is an authentical TWO stages amp ,
providing we count the cascoded differential as
a single stage..
This latter provide 20 db of OL gain, while the
VAS bring the remaining 74db OL gain to reach
the 94db total OLG.
Old 24th September 2010, 04:16 PM   #1004
Sheldon is offline Sheldon  United States
Originally Posted by pooge View Post
Roender,
The LED's set the base/emitter voltage. To maintain the specified current, just change the emitter resistor along with the LED.
Sheldon
Old 25th September 2010, 08:56 AM   #1005
and measure the current through the resistors to check it matches the design value.
This is where builders can benefit from three builders' schematics.
Basic to understand the circuit.
Voltage values added for error checking.
Current values added for error checking.
Most solid state circuits depend on current values through various components to determine overall performance.
If this information is missing then the builder never knows if his clone matches the Designer's Performance Targets
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th September 2010, 12:18 PM   #1006
Hi.
Does anybody know if one NJL diode must be bypassed, than perhaps we can use NJW device instead as they have the same die (for one device only)?
If for pristine and pure adoration - it's diyAudio dedication!
Old 26th September 2010, 03:35 PM   #1007
Originally Posted by AndriyOL View Post
Hi.
You could do that, but why? BTW, you'd have to redesign the PCB or twist the device leads around - they are not in the same order for NJL and NJW.
Sheldon
Old 26th September 2010, 05:17 PM   #1008
Sheldon
They are cheaper and more easy to find when you are going to built HT. NJL types aren't available for now.
Btw, where you found that they are not in the same order. NJW datasheet lack of pin alignment. Maybe in Onsemi forgot about it.
Old 26th September 2010, 05:53 PM   #1009
NJW0281/0302
http://www.onsemi.com/pub_link/Collateral/340AB.PDF
Compare it with the datasheets of NJL's with pin alignment.
Old 29th September 2010, 02:44 PM   #1010
zdr is online now zdr  Belgium
zdr's Avatar
What are the chances that these are real, as filtering caps for power amp:
2PCS Nichicon KG Gold Tune Audio Capacitor 10000uF/50V [KG Gold Tune 10000uf/50V] - $20.00 : DAC,Audio Amplifier,Hifi Amplifier,Tube Amplifier,Hlly Audio, Hlly Electronics
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 03:03 AM
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 27 9th July 2010 11:56 PM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 06:45 PM
Copyright 1999-2017 diyAudio
