Old 21st September 2010, 04:11 PM   #991
Have you looked at the PCB layout?
What is located where those black mysteries reside?
A pair of To126 transistors.
Does that give you a clue rather than reading.
Old 21st September 2010, 04:13 PM   #992
housing is offline housing  Hong Kong
You better look at the picture more carefully. Are the 2SC3423's that huge?
Old 21st September 2010, 04:13 PM   #993
zdr is offline zdr  Belgium
zdr's Avatar
Now, I have to ask a stoopid question: what is the purpose of heatshrinking together a LED and a single transistor?
Old 21st September 2010, 04:15 PM   #994
is there anybody out there that reads the thread and what Roender has to tell us?
Old 21st September 2010, 04:16 PM   #995
look at the datasheet. It tells you that 2sc3423 are To126.
Old 21st September 2010, 04:18 PM   #996
I have partially populated PCBs, and you don't have to tell me that 2SC3423's are TO126. I'm using those that I bought in the 1990's.
Old 21st September 2010, 04:23 PM   #997
zdr's Avatar
No, I mean this black thing circled in red.
It does look like four transistors in a hug with heatsink.
Old 21st September 2010, 04:30 PM   #998
Andrew,
Did I only read?
Old 21st September 2010, 04:45 PM   #999
zdr's Avatar
I did read it once few months back, but due to the noise posts like this, it's kinda difficult to trace back what you need
Old 21st September 2010, 06:03 PM   #1000
Sheldon is offline Sheldon  United States
Just there to thermally couple the transistors and the diode. It's a refinement more than a necessity, as they are touching anyway. The thermal time constants are fairly large compared to music signals, so they just keep bias drift lower. You can use heatshrink tubing there, as the total dissipation is low.
Sheldon
Single stage amplifier Skorpio Pass Labs 33 5th January 2011 02:03 AM
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 27 9th July 2010 10:56 PM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
