This looks like a fairly impressive amp...
Old 7th November 2007, 09:38 PM   #1
Conrad Hoffman is offline Conrad Hoffman  United States
Default This looks like a fairly impressive amp...
Here.
Old 7th November 2007, 09:47 PM   #2
imix500 is offline imix500  United States
imix500's Avatar
Nice. It's about time they came out with a new model.
Old 7th November 2007, 09:52 PM   #3
davidallancole is offline davidallancole  Canada
Thats big.
Old 8th November 2007, 03:03 AM   #4
gni is offline gni  United States
gni's Avatar
Looks like it would be used in the prison system to electrocute
serial killers! Looks like the damn think would melt anything you
could hook up to it. . . .why!
Old 8th November 2007, 06:33 AM   #5
djk is offline djk
djk's Avatar
Old Crown MA10,000 with facelift. Not very much power by today's standards.
Will swing in excess of 200VRMS (10KW) mono into 2 ohms:
http://www.crestaudio.com/media/pdf/10001_10-15-97.pdf
Of course, if you need 18KW into 4 ohms in one rack space:
http://pro-audio.powersoft.it/download_get.php?obj=600
(will burn up any single speaker I am aware of)
Candidates for the Darwin Award should not read this author.
Old 8th November 2007, 08:12 AM   #6
GK is offline GK  Australia
"Fast
40V / millisecond slew rate"
Huh?
Old 8th November 2007, 10:37 AM   #7
Ahh!
but it's got four handles so that two people can try to lift it.
It must be good then.
regards Andrew T.
Old 8th November 2007, 11:25 AM   #8
djk is offline djk
djk's Avatar
It's weight exceeds the maximum OSHA limit for a two-man lift.
I wouldn't mind having one for the bedroom system, I wonder if the utility would run three-phase to my house?
Old 8th November 2007, 12:04 PM   #9
Gordy is offline Gordy  United Kingdom
Originally posted by G.Kleinschmidt
"Fast
Huh?
That's what I thought and then noticed that they go on to say
" 41 volts per microsecond " in the spec. document:
http://www.aetechron.com/7796specsheet.pdf
Old 8th November 2007, 12:23 PM   #10
imix500's Avatar
And they will. We have one of these sitting on the shelf. No one will use it! After Fifty Cent blew up 4 EV X Subs with it.
This looks like a fairly impressive amp...Hide this!Advertise here!
Will pay an experienced UK - based member to build a fairly simple circuit. iamweasel Swap Meet 1 14th March 2012 09:49 PM
Fairly simple, relatively discrete switching regulator BWRX Power Supplies 7 11th September 2006 04:54 PM
An easy and fairly inexpensive DIY Mini Monitor with a Fullrange Driver ThorstenL Full Range 33 6th July 2006 03:34 PM
Hopefully a fairly easy problem for you lot! Fraser Solid State 1 6th March 2004 06:26 PM
FS: Fairly modified ASL Wave 8 tube monoblock amps Saurav Swap Meet 0 8th July 2003 06:34 AM
