#2 | |
Alex |
#3 |
This opamp spec sheet looks fantastic. BTW, can it drive a 32ohms headphone or is it good for an opamp based power amp since the current output is +/-100mA.
Thanks. |
#4 |
Looks pretty nice.
Though the high value feedback resistors will ruin noise performance. |
#5 |
Electrons are yellow and more is better!
The performance is similar other CFB opamps like the TPA6120 but since I like CFB it looks wow.
/Per-Anders (my first name) or P-A as my friends call me |
#6 | |
#7 |
I understand how CFB works. Look at page 6, good stability appears to require at least a couple Kohms of feedback resistance.
This CFB opamp is optimized for slightly higher values in the feedback network than many other opamps. It's not a huge concern, but it is a valid and considered complaint. |
#8 |
I don't see the point. 1.2kOhm isn't the issue I think.
The slew rate is extraordinary. I would test how it sounds in a preamp but National wants 30$ for 4 sample chips! Anyone just tried it? |
#9 |
1.2Kohm would be an issue, if u multiple it with 16pA/rtHz current noise density. But that's the case only when gain is low.
| Best OpAmp for Audio Alchemy DITB | arupg | Digital Source | 58 | 23rd November 2010 12:56 PM |
| Best opamp for audio, operating at +5V only | trodas | Parts | 4 | 21st August 2008 06:34 AM |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 02:15 PM |
| best TI audio dual opamp | Leolabs | Chip Amps | 3 | 18th June 2005 07:12 PM |
| Anyone know this audio opamp? | janneman | Solid State | 4 | 29th May 2004 11:51 PM |
| Page generated in 0.10478 seconds (77.54% PHP - 22.46% MySQL) with 10 queries |
