Old 1st November 2007, 05:38 PM   #1
Default A common ground between preamp and amp
I'm about to build a pre-amp to connect to my amp (Velleman 4004B) and need to know if there are any problems in grounds between different sources (the amps and the audio input and output).
For example, my battery operated pre-amp (I could make one powered by a plug-in transformer) will have a common ground with my audio input and audio output. The output of the pre-amp will then become the audio input of the next stage, the power amp. This amp also has a common ground between audio input, the amp itself and then audio output.
Should I have any concern that two different amps (pre-amp and amp), powered from two different power supplies [one possibly a battery where (-) is ground] is also tied to audio in and audio out with a common ground? Will that create any problems? If so, what are the solutions?
Old 3rd November 2007, 12:22 PM   #2
Gordy is offline Gordy  United Kingdom
It's difficult to comment without seeing the circuit, however in general there should be no problems with a 'ground' formed from a battery being tied to mains ground. In effect the mains ground becomes the reference point and the battery ' + ' supplies a voltage relative to the mains ground.
Grounding is not an easy subject, so best advice is to indulge in a little background reading...
http://www.gbaudio.co.uk/data/ground.htm
(Ground loops...)
http://rane.com/note151.html
(Grounding and shielding notes from Rane)
http://www.tcaas.btinternet.co.uk/jlhearthing.htm
and
http://sound.westhost.com/earthing.htm
(Grounding basics)
Old 3rd November 2007, 03:36 PM   #3
Thanks. Yikes....it's complicated.
Indeed, I had two concerns in an audio circuit: ground loops and audio hum. The references authoritatively talk about those subjects.
Old 3rd November 2007, 04:03 PM   #4
I suggested in another thread that the pre-amp grounds for each channel be kept separate for best immunity to loops and hum.
The consensus was this should not be necessary.
regards Andrew T.
Old 3rd November 2007, 09:00 PM   #5
If taking things to extremes I would look at separating them as you suggest. However in practice it's more a case of separating the signal (i.e. current) return loop flow paths. If done with consideration this can be done well while still using a single overall ground plane (...assuming that a pcb is used).
common ground or not? Mordor Car Audio 5 7th October 2008 12:08 PM
Phono stage common ground hum!! ungie Analogue Source 11 2nd January 2008 11:01 PM
Common Ground layout on Eagle -_nando-_ Everything Else 18 17th December 2007 03:03 PM
Adcom...common ground amp?? Heiney9 Solid State 59 25th October 2005 02:06 PM
Page generated in 0.08631 seconds (71.42% PHP - 28.58% MySQL) with 10 queries
