Hi,i'm max from italy!and first of all sorry for my bad english.
i have 30 years old. i'm new for this fantastic site, but i have a discrete experienxe in AUDIO speaker/amplifier/cables DIY see my site http://arkangel-speakers.blogspot.com/ i have found a lot of information on diyaudio.com about transconductance audio amplifiers. Very interesting informations but in reality...... i'm an AUDIO DIYer.. and i have a dream... to built a Current Amplifier for audio applications usyng transcoductance operational amplifiers or other methods In teory a current amplifier, is a device with an infinite output impedence. we need a big band width,,,low distortion....bla......bla... But if we built an amplifier that convert an input voltage signal of 1-2 volts (that comes from a preamplifier for example) into a current output proportional to this signal (for example 6 Amperes for a 2 volts input) we will make the goal in my opinion. In this case, if we use a single speaker system or a no crossover system (my case But a current amplifier has an infinite output impedence (example 10-20 kohm) so is it impossible that the voice coil generate Electro Magnetic Feedback into the amplifier (introducing distortions and phase changes) The Chain is ...open..from 20 hz (when the voice coil impedence is low) to 20 khz (when the voice coil impedence is high).... The impedence chain from the amplifier to the voice coil is OPEN..... In my opinion this is the nirvana for an audio system, if you use a good single speaker system or a no crossover speaker system. in your opinion there are OTAs in the market to reach this dream?? (LM13600 or LM 13700 have low current output i think....) there are electrical drawings with this OTAs for audio applications? who wants to reach the goal with me? i hope you can help me to reach this dream.... thanks max
open your mind |
#2 |
The principles and execution are relatively easy : http://sound.westhost.com/project56.htm |
#3 |
tahnks for the answers, but i think we are too far from the solution....
in that link i can't find the solution......how to realize a real constant current amplifier for audio applications. max
open your mind |
#4 | |
Take a look at www.firstwatt.com and www.passdiy.com both has the info you're looking for. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#5 | |
Basic opamp theory http://pc31.fauser.it/operazio/operazionale.htm http://www.etec.polimi.it/studenti/m...pAmp/index.htm |
#6 |
HI Gaime...anche tu qui?? (io non vado su VDH da tempo....li ci sono le solite.....).
hi gaime, yes, i understand see this page http://www.national.com/mpf/LM/LM3886.html and....referring this link and your links, http://pc31.fauser.it/operazio/opera...htm#transcondu but i have a doubt to use an LM3886 as a current amplifier (figure 21 of your link): 1) is it not the natural....use of this OPAMP 2) R2 is 20 kohm. in the case (for example) that R1 is 10 ohm, I output is 2000 I input. If the input is 2 volt and R input is 10 kohm , Iout is 0,4 ampere......to low... 3) are you sure that in this configuration there are no oscillations? thanks! max |
#7 | |
Hmmm....... not much hope then ..... it is all there, |
#8 |
thanks sreten for you help!!!
i ahve appreciate it! Giaime say that an operational amplifier like the LM3886 or the LM4780 can be used like a current aomplifer. in your opinion the LM4780 kit is changible in a current amplifier? Attached to this mail there is a file with a my personal interpretation....of a current amplifier.... I don't have pspice or other software, so i don't know if this current amplifier is good...or not.... Is it possible to have an hand please??? in your opinion is it right? oscillate or not? if is it right can you help me to determine the Output impedence, the current gain, the output current and the input impedence? Do you like my idea? i hope you can help me to reach this goal.... this is the original configuration (i use stereo mode) http://www.audiosector.com/lm4780%20amp.pdf thanks max |
#9 |
Download the free TinaTI circuit emulator and play with it. http://focus.ti.com/docs/toolsw/fold...t/tina-ti.html If you cannot manage the above you should go nowhere near a real circuit with a soldering iron trying to change its operation. And yes you can modify it to any output impedance you like, including very high impedance constant current mode, as opposed to the very low impedance constant voltage mode. |
#10 |
this is the the idea......
| Designing my Dream Theater audio system | MaximumPuffer | Multi-Way | 77 | 21st November 2008 01:01 AM |
| About the real power of an amplifier. | dex13 | Car Audio | 4 | 17th August 2007 12:23 PM |
| real beginner amplifier | inadaze | Solid State | 8 | 10th May 2007 03:45 AM |
| My first real amplifier | Solid Snake | Solid State | 18 | 5th June 2003 12:27 AM |
| Page generated in 0.12824 seconds (80.30% PHP - 19.70% MySQL) with 11 queries |
