VERY old school amp VERY old school amp - diyAudio
VERY old school amp
VERY old school amp
Old 1st November 2007, 01:44 PM   #1
Dan2 is offline Dan2  South Africa
Default VERY old school amp
i have a mosfet amp that looks like it came from the stone age ( well you can see all the parts have been hand soldered in) but it still works well and can drive a pretty decent speaker.
it has the preamp built in - so all u have to do is hook up a cd player, speaker and it plays music.
the only problem is that the amp distorts before it reaches its power limits (i think), because the supply voltage doesn't drop too much (maybe 1 volt) and the bass doesn't thin out, and the amp doesn't even get warm
is this just how mosfet amps work or does it sound like i could get some more power out of this amp?
Old 1st November 2007, 02:25 PM   #2
poynton is offline poynton  United Kingdom
poynton's Avatar
Could the CDplayer be overloading the input ??
A photo and schematic would help.
Andy
Old 1st November 2007, 02:55 PM   #3
Mosfet amps generally perform better with a higher bias current than a BJT amp.
This usually means that it runs warmer. Odd that you say it does not warm up.
I wonder if the distortion is a crossover problem?
Can you identify how to measure the output stage bias current?
Can you estimate the heatsink capacity and temperature rise?
Can you tell us what the output stage consists of? Driver and output device type numbers and number off.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd November 2007, 01:11 PM   #4
i don't have a schematic of this amp, sorry. i can tell u what is written on the mosfets : SGS 9805 DB116 (i think they are mosfets)
i tried looking for the datasheets of the DB116's but no luck.
here are some pics
Old 2nd November 2007, 01:13 PM   #5
from the side
Old 2nd November 2007, 01:14 PM   #6
Old 2nd November 2007, 01:27 PM   #7
Elvee is offline Elvee  Belgium
Elvee's Avatar
Looking at the pictures, it seems pretty sure it is not a mosfet amplifier. In fact, the output devices might even be germanium.
The first thing I'd do is to check the electrolytics : there is a number of them, and after 40y or so, there is a good chance one or two have dried out.
LV
Old 2nd November 2007, 02:15 PM   #8
poynton's Avatar
What are the numbers on the other transistors ?
Andy
Old 3rd November 2007, 11:33 AM   #9
how do you check the electrolytics??? and what happens to the amp when the caps dry out? 'cos it still works well, it just doesn't seem to run at its full potential.
i don't suppose you can guess the power output, maybe??
Old 3rd November 2007, 01:42 PM   #10
poynton's Avatar
Andy
Any answer ?
Also what volume control arrangement are you using?
Andy
VERY old school ampHide this!Advertise here!
Old School Fan syncro Introductions 2 8th May 2009 10:25 PM
Old School F5 by ZM Zen Mod Pass Labs 77 27th January 2009 08:03 PM
Old School favorites go bad while I'm out of school...HELP! HayaBuddha Car Audio 5 26th March 2007 05:20 AM
Old School Top 5 mgibson Solid State 7 5th July 2006 05:18 PM
old school fun chainenoble Multi-Way 0 21st May 2006 06:23 PM
Copyright ©1999-2017 diyAudio
