Old 31st October 2007, 10:43 PM   #1
Default Audio Amplifier Project question
Hi guys,
I'm trying to build an audio amplifier with tone control for one of my circuit design courses. I'm supposed to use either the lm833 or the ne5534 opamp to provide a gain of 10 and supplying maximum power to a resistive speaker load, upto 20 khz. The circuit should also be able to boost the treble and bass and provide attenuation up to 10dB before being fed to a speaker.
I have no idea about how to go about building this circuit. I got a hold of the lm833 datasheet, from here:
http://cache.national.com/ds/LM/LM833.pdf
and it has a circuit for tone control. But I'm not sure if it will do everything that I've been asked to do, or how to modify it to suit my requirements.
I'll be very grateful if anyone could provide any tips or hints on how to go about this, because I have to complete this project as soon as possible.
Thanks in advance.
Dev
Old 31st October 2007, 11:00 PM   #2
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
The tone control schematic in the datasheet seems to be just what you're looking for; you'll just have to tailor the component values to suit whichever frequencies you'll want to boost/cut.
And regarding the attenuation... Wouldn't that be simplest to do with a pot, or a stepped attenuator? And i do hope that resistive speaker has a considerable resistance, because this poor little chip can't dissipate a lot of heat without burning up in the process
Old 31st October 2007, 11:38 PM   #3
This chip will serve as a tone control only. It will boost and cut both bass and treble. You can use the values on the schematic. One circuit per channel.
But, this will have to feed a power amp that will deliver 20 watts at 20khz to meet your project requirements as you expressed them. Also, depending on the input signal level, you may need a preamp stage.
You might seek advice in the chip amp forum since you sound like you are in a hurry.
Don't jump on me guys! He didn't specify the amp had to be a discrete.
Poor stereo mix? Switch to mono! Perfect.
Old 1st November 2007, 01:32 AM   #4
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Well then get a LM1875 as the power amp task.
Old 1st November 2007, 01:51 AM   #5
ttan98 is offline ttan98  Australia
Leolabs,
where do you live in Bukit Mertajam? it must be hard for you to get good quality parts over there...
I am an ex-Penangnite...now I live in Melb., there you go.
Old 1st November 2007, 01:54 AM   #6
Leolabs's Avatar
I usually go to Jalan Kampong Benggali near the NBCT.
Old 1st November 2007, 02:00 AM   #7
I am not so familar with B.M.
Buy via post, you can pay now via Paypal, much cheaper transaction cost. Postal charges are the killer.
with US dollar dropping you must find parts getting more expensive? good for exporters and not for importers.
any chance of ringgit revaluing?
Old 1st November 2007, 02:03 AM   #8
Leolabs's Avatar
Don't mind about the price as long as it's worth the price.Do u have any MSN contact???Sounds like we are hacking Thisisme's topic here.
Old 1st November 2007, 02:09 AM   #9
I am not working, are you?
don't let your boss catch you on the net?
sorry I don't have MSN. you can email me the address can be found using my profile if you like.
signing off...
Old 1st November 2007, 03:34 PM   #10
Default re
Thanks a lot for the help guys! Are there any any power amps that I could use besides the LM1875? How do I decide which is the best power amp suited for the job?
Also, about the attenuation, would that go in the tone control stage or the power amp stage?
Thanks again!
Dev
Schematic: Audio Innovations, The first audio amplifier maartentje Tubes / Valves 22 25th February 2010 06:34 AM
(question) TBA820M audio amplifier nandax Chip Amps 13 22nd January 2009 01:12 PM
My OLD Project....... cheap tube audio project!!! tube-lover Tubes / Valves 4 8th May 2008 09:26 PM
Audio amplifier project kits syber Chip Amps 2 6th December 2006 07:42 PM
LAB10 Audio Amplifier Project lineup Solid State 25 8th October 2006 01:27 PM
Page generated in 0.09584 seconds (78.17% PHP - 21.83% MySQL) with 10 queries
