Old 31st October 2007, 02:15 AM   #1
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Arrow Differences between this two kind of input stages???
Any big differences between this two???
Old 31st October 2007, 12:28 PM   #2
ilimzn is offline ilimzn  Croatia
Well, yes, your diagram B is not drawn correctly (wrong polarity of input Qs makes for their B-E junctions being in series across the power supply).
Old 1st November 2007, 01:18 AM   #3
Leolabs's Avatar
VERY VERY SORRY !
Making a big mistake of the schematic.Here is the corrected one:
Old 1st November 2007, 02:11 AM   #4
I don't think either on them will work very well. The circuit is too dependent on the Vbe drops of the various transistors. It could be that with a zero input the transistor currents will be too large and the devices overheat and burn up.
Old 2nd November 2007, 01:44 AM   #5
Leolabs's Avatar
If so,why certain manufacturer still using them,such as Accuphase???
Old 2nd November 2007, 04:37 AM   #6
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I can't see why both shouldn't work, however it must be in a very low Current mode for both circuits.
Do you have a scan of actual the Accuphace circuit?
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 2nd November 2007, 02:08 PM   #7
wg_ski is offline wg_ski  United States
Default current-mode feedback stage
It will work, but you really need all 4 transistors inside the same package or it can go into thermal runaway. Or, more correctly, force the VAS that follows it to go into runaway. Transistor arrays are a solution, but what really works is the old LH0002 current buffer. The one in the "N" package is required, because the collectors of the second pair are brought out individually rather than tied to the first stage emitters. It really wasn't meant to be used for that, but it can. Elantec used to make a whole family of current-mode op amps with both input and output stages based on that topology.
Power amp input stages from National Calvin Solid State 1 14th July 2008 06:18 PM
Cascoded LTP input stages Mindaugas Solid State 20 13th April 2007 01:21 AM
Input stages - to decouple B+ or not? andyjevans Tubes / Valves 1 9th March 2004 10:28 AM
Reduced rails for input stages. K-amps Pass Labs 4 10th February 2004 06:41 PM
Dual-differential input stages Jon T. Pass Labs 14 2nd October 2001 08:53 PM
Page generated in 0.09096 seconds (72.65% PHP - 27.35% MySQL) with 11 queries
