diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   NEC 2SD180 Trannys (http://www.diyaudio.com/forums/solid-state/110948-nec-2sd180-trannys.html)
dark_avenger 29th October 2007 09:50 PM
NEC 2SD180 Trannys
hey,
i've got an old amp that has managed to blow the 2 transisters on the right channel. just wondering if anybody knows somewhere in aus where i can find replacements
they are
NEC 2SD180
LA07
cheers.
linuxguru 30th October 2007 04:59 AM
That's an NPN 80V, 5A, 50W, TO-3 transistor, with the PNP complement 2SA626. There are many better transistor pairs available now - for instance, ON Semi MJ21194/21193 or MJ31184/31193, with much higher voltage, current and power dissipation ratings.
When replacing the transistors, check the pinout and replace both transistors (NPN and PNP) in the pair.
dark_avenger 30th October 2007 09:43 PM
thanks linuxguru the amp is class a and only has 4 of the nec transisters. not complamentry pairs.... do have a suggestion on a transister to replace them all with ?
wg_ski 30th October 2007 11:21 PM
Being a class A amplifier is enough reason to use 'overkill' trannies like the MJ21194. But if you had a cheap source for 2N3773's (or else anything with a purely thermally limited SOA at 80 volts) they'd work, too.
linuxguru 31st October 2007 06:07 AM
Since it's class-A, base-emitter charge storage effects (capacitance) don't play a significant role - so you can go with a bulletproof, monster-die tranny, even with its larger capacitance. I'd second the recommendation to go for an over-engineered, relatively-recent TO-3 like the MJ21194 or 31194 - just ensure that the beta exceeds that of the original, over the operating range.
jacco vermeulen 31st October 2007 07:51 AM
Sansui 555 ?
GK 31st October 2007 12:47 PM
2 Attachment(s)
Originally posted by jacco vermeulen
Sansui 555 ?
jacco vermeulen 31st October 2007 12:54 PM
Bra wrencher,
you're the ace, i missed the Gas Research part.
Oz seems to be the place for high power LPG, a lot cheaper than overhere too.
(the 5PPM biggy looks impressive as well, think you bought the last of the 404's)
dark_avenger 31st October 2007 09:59 PM
cheers for all the advice i'll track down some MJ21194 and give them a go.
david
GK 1st November 2007 04:35 AM
Bra wrencher,
And here the government actually gives you a $2000 freebie grant to help towards the conversion cost, as part of an environmental initiative to encourage people to switch to a less polluting fuel.
This, in part, makes it easier for all us petrol heads to get our 30-litre-per-hundred-kilometers-fuel-guzzling 6 litre-plus hotted up V8ís converted for use as economical daily drivers on a cheap fuel.
Thatís pretty funny, I reckon.
Copyright ©1999-2017 diyAudio
