100w into 1.3ohms
100w into 1.3ohms
Old 1st December 2008, 10:50 PM   #21
zoranaudio is offline zoranaudio  Macedonia
zoranaudio's Avatar
Well in our electronic journal "emiter" few months ago was presented a 1000W into 1 ohm amplifier, everything but schematic.
I am not sure if this is already patented or still patent pending mode.
Made by our people.
zaudio
Old 1st December 2008, 11:15 PM   #22
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Made by our people.
Who is "our people"?
I have designed and built an amp capable of this power. Details here.
I use it every day. With the power supply it has now, it can do nearly 800 watts into 2 ohms, so 1000 into 1 ohm shouldn't be a problem.
Old 1st December 2008, 11:22 PM   #23
zoranaudio's Avatar
I am looking for this schematic:
http://audioacdc.com/downloads/AC.pdf
zaudio
Old 1st December 2008, 11:26 PM   #24
MJL21193's Avatar
Yes, you've made that clear in a few threads.
Old 1st December 2008, 11:28 PM   #25
zoranaudio's Avatar
Yes, but that people that time wouldn't like this schematic can be seen, unfortunately .
zaudio
Old 1st December 2008, 11:35 PM   #26
MJL21193's Avatar
I'll go out on a limb here and say that it is probably no big deal. Almost any decent amp can swing 1000 watts into that low a load - briefly, given enough rail voltage. To maintain this power at that impedance requires lots of outputs., with just a run of the mill front end to drive them.
Old 1st December 2008, 11:51 PM   #27
boraomega is offline boraomega  Serbia
This might do the job....
Laonicus Chalcondyles : “Tryballos = Serbos, autem gentem esse totius orbis antiquissimam et maximam, compertum habeo...”
Old 2nd December 2008, 07:00 AM   #28
zoranaudio's Avatar
It was very unbelievable when on a local TV station I heard and saw this "thing" and simply I can't understand
I saw something small like a box of cigarettes with some fan.
And ask myself: how can this give 1000 W @ 1 ohm???
Later this Patent was presented in our electronic magazine "Емитер"
but just the block diagram, not electrical schematic, and than understand that power supply was not included into that "box of cigarettes".
Later i found that this was stable even @ such a low impedance with values 0.? said 5000w @0.2ohm continues power and plus stable, I said woooooow I must be on other planet
This guys (constructed /designed by two guy's) was on the TV and they promoted that amplifier in the Cinema for some premiere movie, and one of them says: looked the size, if you put standard PA amps to achieve this power you will need a lot of more space, cos this can drive (don't keep on my word) 16 speakers!!! connected on a "cigarette box"- My words: Amazing
Never done before, my congratulation.
zaudio
Old 2nd December 2008, 01:53 PM   #29
fotios is offline fotios  Greece
fotios's Avatar
Zoran
You have been reported in this commercial product in 3 different threads. I think that is a clear advertisement.
I repeat that my posts are not aggressive towards you.
I just tried to defend the character of this forum.
Fotios
Old 2nd December 2008, 02:18 PM   #30
kristleifur is offline kristleifur  Iceland
Default Re: 100w into 1.3ohms
Originally posted by Powertimes_2
Does anyone know of an amplifier that can produce around 100watts into 1.3ohms.
It is for a sub-woofer I recently got of a friend, it is a SONY SS-WP1000.
The Specifications are attached go to page 57 on the PDF for more specs.
For one, the Tripath TA4100A chip can do it. It's a Class D chip, but better sounding than most Class D car audio amps AFAIK. (You can use it full range.)
The 41Hz.com Amp9 is one implementation: http://41hz.com/main.aspx?pageID=130 - I'm not sure much power it gives you exactly, but this chip can give at least 200W into 1 Ohm when bridged. Closer to 400W, some say.
The Amp9 is the only one I know about specifically. It is an unassembled kit, there are more brands available. This includes prebuilt modules and whole amps containing this TA4100A.
100w into 1.3ohmsHide this!Advertise here!
Eti-480 100w Amp Help Please jacquesl Solid State 25 6th May 2017 08:05 PM
100w Stk nbcd Chip Amps 14 30th September 2009 01:36 PM
Evolve Amps 100W+100W Stuff 4 Sale finwbu Swap Meet 4 8th June 2005 10:57 AM
ETI-480 100W Amp .. please help jacquesl Solid State 25 29th May 2005 07:53 PM
100W amp Vivek Solid State 13 23rd December 2001 07:57 PM
