Suggestions for Building sound system
Old 12th February 2003, 04:52 PM   #1
TomJ is offline TomJ  United Kingdom
Question Suggestions for Building sound system
I am planning to Build rod eliots projects 3A(60W-100w amplifier),88(preamplifier),09(linkwitz riley crossover). Will these projects work well together. I am going to use the amp for 60W amplification which i will have bi-amped.
Does any one who has built these projects have an tips or had any problems with them. This will be me first time building an amp,preamp,crossover they all look fairly straitforward I have access to a etching tank and some realy good software for making artwork.
How much is this whole lot likly to Cost.
Old 18th November 2006, 02:43 PM   #2
gni is offline gni  United States
gni's Avatar
Default Mods, Kits, Home Built
Always start by modifying first. . .learn, try some kits that come with
everything, then build from the ground up. . . .the Elliot kits are part
way between kits and home built. . .you find the parts. . .the boards
are ready-made (most of the time). I've not heard any bad words about
Elliots designs.
Let us know how it works.
Chris
Old 18th November 2006, 05:13 PM   #3
XEAGLEKEEPER is offline XEAGLEKEEPER  United States
XEAGLEKEEPER's Avatar
Your going to need more than one P3A if your going to biamp. I've had real good luck with Rods stuff ie. 4-P101 boards and 2-P39 boards very good quality fiberglass boards and very easy to follow build instructions. Tons of tech support on the forum.
Ret. USAF... AKA- Avionic *** Solder slinger for hire...***
Old 18th November 2006, 11:49 PM   #4
gni's Avatar
Default Support for Elliot Kits
There you go. . .yet another good word about Elliot Sound! Many
people out there doing it themselves. . . it isn't rocket science.
Chris
Suggestions for Building sound systemHide this!Advertise here!
Building a 2.1 system. Any suggestions? cwteoh Chip Amps 22 12th December 2011 07:28 PM
SQ System - Need your suggestions omar_uh Car Audio 2 31st March 2009 09:44 PM
novice seeking help in building a sound system Snapshot Multi-Way 10 25th December 2008 09:48 AM
Building First Amp, Need Help/Suggestions MotoMan_Yz400 Class D 1 7th January 2008 06:03 PM
Building my first 4th order BP box, any suggestions? theCat Subwoofers 8 23rd May 2005 04:01 PM
