Old 24th October 2007, 03:49 PM   #1
Dan2 is offline Dan2  South Africa
Default 2 channels to one (not bridged)
hey guys, this might be a stupid question, but at least it will clear up some confusion for me.
I have a stereo amp and inverted one channel so it can be bridged. it works well with a 8ohm speaker, but gets really hot with a 4 ohm driver (not much distortion though)
is there any way to "parallel" both channels to one speaker so that both channels share the current.
basically one channel is loud enough, but i only want to run one subwoofer off it and i don't want to waste the other channel (and i want to try preserve the transisters a bit)
Old 24th October 2007, 03:59 PM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Use a dual-coil speaker with the amp as dual mono
Andy
Old 25th October 2007, 06:34 AM   #3
well i already have the speaker so im not going to buy anouther one. i was thinking that if i have the same signal on both inputs (mono) and link the 2 positive outputs ('cause there should be no voltage drop between the two) and have 1 speaker terminal connected to the link and the other terminal to ground output.
could this actually work?
Old 25th October 2007, 06:42 AM   #4
djk is offline djk
djk's Avatar
In theory, yes.
In practice, no.
The AC gains and DC off-set would have to match perfectly, and even then I would want to sum the output currents through a pair of 0R5 resistors.
Candidates for the Darwin Award should not read this author.
Old 25th October 2007, 08:19 AM   #5
Forget your paralleling proposal.
The single amplifier running off the stereo power supply will perform better than having two amplifiers running from a common PSU.
Most cheaper commercial gear is strangled by undersized power supplies. The reason being that a good PSU is more expensive than a good amplifier, so the good PSU goes out the window to save money and weight and volume and case size and distribution costs etc.
regards Andrew T.
Old 25th October 2007, 08:52 AM   #6
Nordic is offline Nordic  South Africa
Nordic's Avatar
Hi Dan, nice to see the sun again, what bass driver are you useing? Maybe the members can recommend something that can drive it more appropriately.
Old 29th October 2007, 08:02 AM   #7
well i want to run a car sub with it, i already have the driver so i don't want to get another.
the reason why i wanted to parallel the amp is because it is a cheap amp - its pretty loud but the output transisters are a bit on the weak side.
i got this idea from a friend who wants to build a chip amp - and he was talking about running the chips in parallel to increase the current.
Old 7th November 2007, 05:04 PM   #8
this is where i got the idea for paralleling the amps. this is from a chip amp data sheet and it shows 2 chips connected to each other.
although i can understand the statement of one amp running better off a stereo PSU, in the case of my amp im not too sure, it has a really nice big toroidal transformer in it, and crappy little output transistors.
so how come you can parallel chip amps but not solid state amps??? (just curious)
Old 7th November 2007, 10:50 PM   #9
djk is offline djk
djk's Avatar
"The AC gains and DC off-set would have to match perfectly, and even then I would want to sum the output currents through a pair of 0R5 resistors."
Old 8th November 2007, 04:08 PM   #10
wg_ski is offline wg_ski  United States
As others have mentioned, paralleling entire amplifiers can have unpredictable results. But you only really need to parallel the output transistors (and maybe the drivers). Disconnect the rest of the other channel and just parallel the "extra" output transistors. Leave in the emitter resistors and base stoppers (if any). All four outputs must be on a common heat sink or this won't work. If they're not, pull them from the disabled channel and add them to the heat sink of the one you're using.
The reason you can parallel chip amps is because the gains and DC offsets are matched, and the protection circuits have almost no lag time if something does go haywire.
Getting Both Channels out of my M-501 Getsum Solid State 1 3rd February 2011 05:50 PM
switching channels 9am53 Instruments and Amps 9 9th June 2005 04:14 AM
WTB: 6 Channels of amp dunderchief Swap Meet 12 26th February 2005 02:17 PM
summing channels ocool_15 Solid State 5 24th February 2005 06:23 AM
I have 5 spare channels--What do I do with them? mikejz84 Multi-Way 8 3rd December 2003 11:09 PM
Page generated in 0.09068 seconds (86.06% PHP - 13.94% MySQL) with 11 queries
