Old 22nd October 2007, 11:32 PM   #1
thedman is offline thedman  United Kingdom
Default integrated amp with active xo?
I'm hoping to build a subwoofer as my first diy project and am looking to use an active xover. I have two integrated amps, one which can be configured as a power amp and one which can't. Is there any way I can use the one that can't be configured as a power amp to take an input from the xover in order to power the sub woofer.
I'm pretty sure I've read that this can't be done, but I'm just trying to understand why and if there is any possilbe way around it. E.g. could I just use no gain on that channel of the xo.
I have never understood ohms etc. even though I tried very hard whe studying physics to get my head around it. So please treat me like an idiot when explaining this.
Thanks for any input.
dman
Old 23rd October 2007, 01:07 AM   #2
audiobomber's Avatar
Yes, you can use the integrated amp to power the sub driver. Just plug the output from the sub crossover into one of the high-level inputs (CD, tuner, aux) of the integrated amp.
You'll be going through an extra stage (the integrated's preamp stage), but it shouldn't matter much just for the sub. You could just use a single channel, or use two sub drivers with one channel for each. You could potentially build an external bridging circuit to combine the channels, but just be aware that the speaker impedance will be cut in half.
Dan
Old 26th October 2007, 03:05 PM   #3
The xo has a mono output for the sub. I then realised I don't know what mono ouput really is - I mean is it just using one of the two input channels or are the 2 input channels somehow combined into one output
Also, is it Ok to just to use one channel on an amp. I was told the other day that it was bad because the unused channel was in effect going into a zero resistance (I really, really don't understand ohms - makes my head hurt)
Old 26th October 2007, 03:25 PM   #4
Did it Himself
richie00boy's Avatar
The unused amp channel will just be floating there, driving nothing but free air so it's totally safe.
Mono usually means the left and right channels are summed together to a single channel.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 26th October 2007, 07:13 PM   #5
What Richieboy said. The mono output is a combined Left and Right channel signal.
What you were told is incorrect. The unused channel is not connected, so it sees infinite resistance (i.e. an open circuit). No problem at all, it just isn't being used.
Dan
Active 3-ways with solen active loudspeaker module soundemon Multi-Way 14 19th March 2009 11:17 AM
Component Suggestion: 2-way active now, 3-way active later CanadianDream Multi-Way 6 3rd August 2007 04:53 AM
Behringer DCX2496 I want to try active biamping using it as the active xover. georgehifi Digital Line Level 3 15th August 2006 07:46 AM
Active 3 Way vs Active 2.1: Too many alignments and too may questions. goldyrathore Multi-Way 1 22nd April 2005 02:42 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.08697 seconds (74.11% PHP - 25.89% MySQL) with 10 queries
