Carver buzz at idle
Carver buzz at idle
Old 21st June 2012, 09:04 PM   #21
AudioSystemsEng is offline AudioSystemsEng  England
hi, i'm getting the feeling you may be lacking some basic electronic skills.
please be careful around the power supply, the primary is 110V in the u.s. and the secondary is up to 250V.
you need to examine amplifiers with an oscilloscope - not a test meter.
You should be looking at waveforms on the D.C. rails, not the transformer.
The rail voltages are in the region of +/- 36V, +/- 50V and +/- 124V.
If you accidentally short these rails with your probes, you'll melt the probe, risk damage to the amp and your eyes.
This really isn't an amp for beginners - its just too complicated and dangerous.
take care,
jonathan
Old 23rd June 2012, 12:26 AM   #22
srinath is offline srinath  United States
I sound more scatterbrained than I am. I have yet to give myself anything worse than a headache working on these amps and I have fixed near about 50 vintage and HT amps. I may not be formally electronically educated and up on terminology ... but I know what a switching transistor does vs a power transistor etc etc.
Cool.
Srinath.
Old 23rd June 2012, 01:30 AM   #23
tauro0221 is offline tauro0221  United States
I was wondering if it is possible to try a "GE-MOV" metal oxide varistor across the triac. This will filter any noise coming from the triac. You most get one depending of the working voltage.
Old 23rd June 2012, 03:05 AM   #24
Soldermizer is offline Soldermizer  United States
Soldermizer's Avatar
This is way above my head. However, I've owned about 5 different M400(a|t) over the years. I killed one that had a slight hum, back in the 1990s. I am inept! When I first hit upon this thread, I wondered if it could be (but turns out to not be) one of the other types of hum this model can do: the unit itself will hum or buzz like a transformer (silent at speakers, but the cube would hum).
Old 23rd June 2012, 03:20 AM   #25
I would try a GE MOV Mouser part no. 576-V220ZA05P $0.36 cents acorss the triac.
Old 23rd June 2012, 03:27 AM   #26
Ian Finch is offline Ian Finch  Australia
Default MOVs
The "knee" of the conductance of MOVs is typically around twice the peak AC line voltage. They usually only target large spikes on the line, so I doubt you'd get much effect, if any, on low voltage hash and spikes.
There are other voltages available but nowhere as common as 130 or 275V types but as they don't have a sharp threshold of conduction, any attenuation will still depend on the size of the spikes.
The killer is that a nominal 130V rating MOV doesn't clamp until >320V!
http://www.eeel.nist.gov/817/pubs/sp...Superalpha.pdf
If only I had listened....
Old 23rd June 2012, 07:32 AM   #27
djk is offline djk
djk's Avatar
A triac for a Carver must be of a type selected for good 4th quadrant firing. If the gate threshold voltage has any asymmetry the transformer core will buzz and saturate.
Candidates for the Darwin Award should not read this author.
Carver buzz at idleHide this!Advertise here!
Amp for IB with low idle consume wingman Class D 5 23rd July 2009 12:53 PM
Carver PM-1.5 Amp buzz humm SoundQuest Solid State 3 24th June 2008 09:36 PM
Carver PSC-60 Preamp - Buzz. AltheaToldMe Digital Source 0 27th January 2008 08:46 PM
Melos triode and computer as source: BUZZ BUZZ BUZZ zigo3 Tubes / Valves 4 28th November 2007 02:11 AM
aleph2,3,5 idle dissipation ? kslim Pass Labs 6 3rd September 2004 04:29 AM
