preamp output stage resistor from output to V- ? ?
It is a Pioneer C21, rather old with output coupling caps which I would like to bypass but there is no DC servo and there is 1V DC on both channels.
I have no manual but will draw a schematic from following the traces.
It should be possible to add DC offset adjustment, must not be 100% stable, some mV is ok.
a discrete output stage could already be operating in ClassA. If it is, then it does not need any extra loading to shut down half the stage and force it into ClassA.
Post the schematic with operating currents or operating voltages. We can calculate the lowest load value that keeps the stage in ClassA and from there make sensible recommendations, instead of flying blind.
