A Shunt-Reg with current source for DAC/Phono needed - diyAudio
Old 11th February 2003, 08:54 AM   #1
Default A Shunt-Reg with current source for DAC/Phono needed
I have build the superreg of Allenwright (for tubes)with a constant current source and a shunt-reg and I like it quite a bit. Now, building a DAC and a Phono-Preamp, I am looking for a similar design which works not only for HV, but as well for 30V or 5 V and giving positive and negative rails.
I have looked around with the search function, but most designs are series regs. As I need only 100-200mA high-quality regged current, I would highly appreciate if the regulator-experts could bring in their knowledge around that.
THX a lot
Old 11th February 2003, 08:59 AM   #2
hifi is offline hifi  Sweden
Maybe you should check The LC audio shunt reg used in the Zapfilter schematic is availble on www.lcaudio.dk
/ Micke
Old 11th February 2003, 09:34 AM   #3
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Shuntregulator
Hi Blitz,
You can use the simple design below. Maybe use a somewhat heftier transistor for the CCS. The diode is a red LED.
I keep asking myself: what is the superiority of the shunt regulator above the series regulator???
Tube shunt regulator for phono amp velvetsunrise Tubes / Valves 5 4th May 2008 05:13 PM
Shunt regulator for a phono pre analog_sa Solid State 23 12th August 2003 10:25 PM
Copyright 1999-2017 diyAudio
