Hafler bias current
Hafler bias current
Old 12th February 2003, 01:53 PM   #11
Fritz is offline Fritz
Mlloyd, Jam,
That makes sense, its all making more sense now that I found the burned fuse in my meter and actually see the current on that fuse. I set it at 280 through the fuse last night and the heat sinks are mildly warm at idle and when playing voice from a movie. I should probably put a more challenging signal through before I turn it up a lot. This weekend I can put it on some decent speakers and see if I can discearn the difference between 280 and say 350. Maybe some less than 20 year old caps after that!
Thanks very much,
Fritz
Old 31st December 2003, 06:26 AM   #12
wrl is offline wrl  United States
What exactly is the device you all are refering to? Output transistors? Just wondering as I'm about to finish rebuilding my DH-200
Thanks,
-Wes
Anything worth doing is worth doing right... and redoing to make it better... and again to fix it back the way it was.
Hafler bias currentHide this!Advertise here!
Hafler 200 bias rudy129 Solid State 66 25th November 2008 02:24 PM
bias voltage vs bias current woodturner-fran Tubes / Valves 3 24th February 2007 11:24 PM
hafler 9180 BIAS+Mods bluesmoke Solid State 25 12th April 2006 04:14 AM
Cannot adjust bias current, Hafler 220 mmerig Solid State 5 31st March 2005 02:28 AM
BOZ Bias Current gema Pass Labs 2 20th February 2002 07:28 PM
