Regulated SLA/battery supply?
Old 15th February 2003, 10:59 AM   #11
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally posted by sangram
Rod Elliot has one on his site - fully automatic.
That won't help in fmak's case. He said "My probelm with lead batteries is leaving the units on and discharging/ruining the whole thing."
Rod's charger senses current and DISENGAGES the charger when the unit being powered is turned on and draws current. So if fmak leaves his preamp on, Rod's circuit wouldn't engage the charger until the batteries were pretty much dead and no longer able to deliver current above whatever threshold was set.
se
Old 15th February 2003, 11:05 AM   #12
sangram is offline sangram  India
se
Sorry, saw that late. Maybe the current sense can be retuned so that recharging happens at only idle current (whatever the quiescent current value is), maybe a small timer would help to not have the charger switch on between songs (10k/2000 uf?) or while changing CDs...
Old 15th February 2003, 07:56 PM   #13
Steve Eddy's Avatar
Sure. But ultimately I still don't see it as needing to be any more complicated than a simple switch.
The way I read his comment, it's not like he's too lazy or forgetful. He just wants to keep the preamp powered up when he's not using it and instead of having that drain down the batteries, he wants something that would kick in at a certain time and keep the batteries topped up.
That being the case, all he really needs is a simple multipole switch that engages the charger when he's not listening. The preamp would still remain connected to the batteries so it would ultimately always be "on." You'd just have to remember to flip the switch when you were done listening.
se
Old 15th February 2003, 08:42 PM   #14
fmak is offline fmak
[QUOTE]Originally posted by Steve Eddy
[B]
Actually, my problem is that I forget. A switch doen't help. I need a trickle charger when the voltage drops below, say, +-10V.
Old 15th February 2003, 09:14 PM   #15
Steve Eddy's Avatar
Ah...
Hmmmm. Well that's a bit more complicated. A simple comparator could detect when you get down to +/- 10 volts, but once the charger kicks in, you'd be above the threshold and it would just disengage. So you'd need another comparator to monitor the current flowing from the charger. The outputs of the two comparators would then feed a logic circuit to determine when to engage and disengage the charger.
Hmmmm...
Ok, how 'bout a simple switch AND a string to tie around your finger to remind you to turn the charger on?
se
Regulated SLA/battery supply?Hide this!Advertise here!
regulated 5V DC supply Tomatito Power Supplies 51 29th October 2012 08:00 PM
bipolar regulated...battery redrabbit Power Supplies 4 25th October 2008 01:54 PM
3 Pin regulated supply VS zener based supply KevinLee Solid State 3 15th September 2008 03:40 PM
regulated supply +- 28V -20A sss Power Supplies 8 14th June 2005 08:30 AM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 09:49 PM
