Old 12th October 2007, 05:38 PM   #11
Default Re: Re: Re: quasi comp
Originally posted by slideman82
I've read power MOSFETs had negative thermal resistance...
yes, go look at the graphs in the datasheets.
Compare Lateral to Vertical FETs and note that lateral change from positive to negative at around 100mA and that vertical change from positive to negative at enormous Amperes Id. They blow up before you can reach the negative coefficient.
Verticals need compensation. Laterals do not need it, but parallel sets do benefit from some feedback by fitting source resistors to each.
Ilimzn was referring to the uncompensated drivers.
regards Andrew T.
Old 12th October 2007, 08:50 PM   #12
Drivers have to dissipate less than 1 Watt with tipical 10 ma. bias so individual U-shaped heatsink can do balance with mos-fet thermal behavior.
The result can be DC offset less than 20mV hot/cold.
JMB
Old 13th October 2007, 04:57 AM   #13
Default ouput conversion
in regards to output stage conversion if michael chua of ampslab practice this to bipolar maybe it can be done also to mosfet compare this attachment we will notice that the only difference is the the output stage
Old 13th October 2007, 05:00 AM   #14
Default attachment 2
attachment 2
Old 13th October 2007, 10:55 AM   #15
Did it Himself
richie00boy's Avatar
Why don't you build that then? The circuit in your first post is not really suited to easy converting to n-channel mosfet by beginners.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 13th October 2007, 11:16 AM   #16
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Driving N-Channel Mosfet QC amp just like a regular bipolar QC amp is one of the biggest mistakes conducted by Diyers
mosfet i/v conversion from D1 with pcm1704 schiller Digital Line Level 4 15th April 2009 10:26 AM
minus 25 on output mosfet amp Jan Deckers Solid State 3 12th April 2009 06:14 PM
Do mosfet output devices age? Geesixty Solid State 10 19th April 2006 03:14 PM
Power amp output - BJT or MosFET? Bill Fitzpatrick Solid State 20 25th April 2004 04:58 AM
output Mosfet for Aleph2 Cephas Pass Labs 14 17th April 2002 04:46 PM
Page generated in 0.10156 seconds (71.32% PHP - 28.68% MySQL) with 11 queries
