Old 11th October 2007, 11:25 PM   #1
Default Yamaha C-4 input selector
The input selector on my Yamaha NS Series C-4 preamp has gone bad. The sound breaks up or fails altogether. Rotating through the inputs sometimes fixes the problem, but it always comes back.
I have no idea how to find the replacement part number, or a source for the part, since I don't think Yamaha makes them any more. Can anyone help me?
If I can't get the Yamaha part, does anyone know another rotary selector that would do the job just as well? Looks are not a consideration.
Thanks!
Old 12th October 2007, 02:57 AM   #2
It may all depend on how many positions and decks the Yamaha uses.
I like the Grayhill selectors, and I use them. Contacts should be at least solid silver.
Old 12th October 2007, 06:34 AM   #3
Bigred is offline Bigred  Canada
Are you sure its actually worn/gone bad or maybe just in need of a blast of deoxit?
Old 12th October 2007, 07:50 PM   #4
It's been cleaned twice. It has 5 positions.
Thanks!
Old 13th October 2007, 09:58 PM   #5
KBK is offline KBK  Canada
I've owned two of them. Once I pulled the switch out and re-clamped the solder points.
They are the usual kind of alps brand custom parts, they cannot be easily replaced by anything.
If any of you have ever taken apart a alps black beauty pot or the like, the failure point can sometimes be that the solder pins are 'clamped' to the plastic film substrate, which is alot like a little circuit board. the connection point is merely a press tight lug contact. So they sometimes need to be re-pressed. the switch needs to be pulled for this effort. There are no guarantees on this fix. As well, the contacts on the switch proper are done the same way and can be similarly fixed.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
"Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti
Old 19th October 2007, 07:34 PM   #6
I was afraid of that. Any idea how I can find the part number and maybe track down a replacement?
Thanks.
Input selector Simo88 Everything Else 25 15th July 2009 01:33 AM
Boz AP1.7 Input Selector PCB Stones Pass Labs 2 14th November 2006 06:08 AM
input selector lawbadman Digital Source 8 10th September 2005 09:45 AM
Input selector: need help Cobra2 Parts 1 8th March 2003 07:31 AM
Page generated in 0.07299 seconds (74.50% PHP - 25.50% MySQL) with 10 queries
